1942 stamped 520 - 4 legger
Discussion in 'Military' started by idahostoveguy, Aug 4, 2009.
  1. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    Got it working for the photo shoot...
    U.S. 1942
    4 legger
    Steel tank
    1249358172-1942_520_4legger.jpg 1249358328-520_4legs.jpg 1249359699-520_fuelcap.JPG 1249359722-520date_stamp.JPG 1249359740-520full1.jpg 1249359766-520_flame1.JPG 1249359779-520_flame2.JPG
  2. flivver
    Arizona
    Sam: Nice Coleman 520 - great flame. I can't figure the number of legs. The Ernie Pyle has 4, my green 41' has 3 and your 42 has 4, a 43' on another site has 4 and Steve's 45' has 3. I give up. Some that are stamped Coleman have 3 or 4 legs and some that have no makers mark have 3 or 4 legs. Mike...
  3. Knight84 Canada
    Steves 45 has 3 legs. I am at the same point Mike... just when I start to figure it out I find out I am out of beer.
    Cheers, hic
    Jeff
  4. idahostoveguy
    Potato Country USA
    Mike,
    I guess I've only ever seen '41s and '45s online. I don't think I've seen any of the other dated stoves except for my '42. Are there '42s with 3 legs????
    sam
  5. flivver
    Arizona
    Sam: Is your 42' a brass or steel tank? The M42' which is a different design and is the forerunner of the M1950 was consistently 3 legged as for your 42' 520 I am fairly sure I have seen 3 leggers. However right now I am seeing double. Mike...Mike...
  6. idahostoveguy
    Potato Country USA
    I'm pretty sure it's steel with the rust on the bottom of it around the rim and on the out side, which can be seen in the first pic....
    sam
  7. bajabum
    California Coast
    I don't know what my tank is made from, but a magnet won't stick...
  8. hydro451
    Hi all,
    Idahostoveguy,
    Nice flame, very nice - who says these colemans won't last 80-100 years - with some minimal maintenance I bet it would run for another 60 years
    Tom
  9. itchy United States
    Durham, North Carolina
    Is there a strict correlation between 4 & 3 feet and small vs large filler hole/cap, respectively?
  10. idahostoveguy
    Potato Country USA
    Thanks for the kind words Tom. Yeah, I was surprised how easily it fired up - a few pumps, light it, and after the initial warm-up of a ferocious, 18-inch, yellow flame got the nice blue flame above. :shock:
    sam
  11. idahostoveguy
    Potato Country USA
    itchy,
    I think age of the stove has a lot to do with the filler cap size rather than the number of feet (maybe I'm wrong here). I know this one is small since the coleman funnel barely fits the opening. Later models have the larger filler cap, for example, the 530.
    sam
  12. ulysses
    ulysses United States Subscriber
    Manasquan, New Jersey USA
    Sam:
    There were multiple manufacturers of the M1941, perhaps one or more followed their own ideas on the number of legs. The post-war 530 would be better for some stabilizing legs.
    I have used an alcohol prime on the stove to reduce the dramatic, pillar of fire affect that comes with the stardard lighting procedure. Although not very visible, there is a prime cup behind the windscreen.
    Paul
  13. flivver
    Arizona
    Paul: The prime cup is only on the later ones made with diesel/kero in mind. Take a look at the Ernie Pyle's and my 1941. I don't think the 42's had them ether. The early war 520's didn't have them. The cup and modified generator made the late war 520 a true duel fuel stove. Nether version needs a prime for gas/ Coleman fuel. The 530 also doesn't have the priming cup I believe. Mike...
  14. idahostoveguy
    Potato Country USA
    The 530 doesn't have a priming cup either. Paul, your are right that the "M" stoves have a priming cup, like the M-1941 and M-1950 stoves. There are two styles of stoves. One style is seen in the 520 and 530 and the other style is the "M" stoves. All of my "M" stoves have the priming cup, while my 520 and 530 stoves have no priming cup.
    Thanks,
    sam
  15. flivver
    Arizona
    Hi all: Last night I called a WW11 vet. friend that was in Patton's army. I did so because of the questions on this post and the fact that he and I have discussed the 520 in the past as he carried one. He says that he hated the priming cup but was under orders to use it at night so the enemy could not see their location. His quote was that the stove "took a week to light" if the priming cup was used. During the day they did not prime the stove. He said all the stoves he saw had priming cups. He also said it would run on diesel/kero without priming. Mike...
  16. hydro451
    Hi All,
    Just wanted to paas this link on
    http://cgi.ebay.com/WWII-WW2-COLEMA...in_0?hash=item4cea617ce3&_trksid=p3286.c0.m14
    It's a M1941/520 on Epay. Evidently Coleman called it a 520 , while the military referred to it as a "M-1941". It has a priming cup and three legs.
    It gets a little confusing sometimes when designations for these stoves can be different and then you throw in the dates involved and it all gets a little muddled.
    Also on the Ebay stove there is a picture of the spare parts and it lists a "M-1942" as a two burner. Could that be what is known as the 523 ?
    Tom
  17. itchy United States
    Tom,
    Pretty sure the same burner is used on both the M-1941/Coleman 520 and the two burner M-1942/Coleman 523. Is that the issue? There is also a 1 burner M-1942 stove, but I don't know if there was a civilian version ever sold.
  18. Knight84 Canada
    Your right itchy. The Coleman 520 uses the same burner head as the 523. The burner head/bell the M-1942 used is very similar but not really.
    Note the rectangular holes on the side to allow the folding pot supports to go through. The 520 burner head has circular holes, among other things.
    The M-1942 (Mountain stove) the M-1950 (536), and the 523 are all inventions of Bestor Robinson. The 520 (M-1941), 530 and the generator was Boyd Tullis. Tullis worked for Coleman Company.
    That said all these stoves share parts or something in common. The U.S. governments doing so no doubt to simplify the production.
    In the orginal patent of the 520 there is no priming/preheating cup. The instruction for the one without a preheating cup are very similar to the one with it. There is no mention of filling the priming cup before lighting. :-k Seems to be something they added to please the military indeed.
    Jeff
  19. flivver
    Arizona
    Hi all: As Jeff said above, the priming cup possibly came from military need. See my post #119810, four posts above. Mike...
  20. Knight84 Canada
    "Military requirements/specs" I think is what happened. The spare parts and multi tool I believe were part of the specification too.
    On another note, the way the M-1942 Mod. Mountain stove is fired up is more "normal" But again fireballs in enemy mountain territory is no good.
    Sorry to go off topic.
    Best regards
    Jeff
