1962 August Coleman 501A (August 1962)
Discussion in 'Coleman No:501' started by presscall, Dec 17, 2014.
    I'm really just revisiting the points Jeff (Knight84) picked out regarded the Coleman 501A, HERE
    Jeff's right, it's pretty much got rid of the potentially dangerous characteristics of its predecessor, the 501, and firing it up (or more relevantly running it for a few minutes) didn't present any drama, by which I mean thermal runaway as the 501 would
    Just confirming the production date here, Coleman not bothering to stamp in the 'A' suffix
    Before I fired it I dismantled it completely and inspected parts, replacing a seal in the tank filler cap ...
    ... and installing a leather pump cup washer instead of the plastic one it had
    I appreciate a well-engineered mechanism and the pricker arrangement with a fast-threaded left-hand-thread ticks a box in that respect for me
    Partly re-assembled
    Evolution, for safety's sake. The 501 on the right had the fuel cock on the vapouriser outlet, so the control knob got very hot (and got hotter and hotter in use to the point of emitting smoke) and were a leak to spring between fuel/air valve and fuel inlet on the left of the tank top and the control valve there would be no way of shutting off the fuel. The 501A on the left has the fuel cock on the correct end of the vapouriser and although the pricker control on the right gets pretty hot in use, there's no thermal runaway and a way of shutting off the fuel at the inlet is incorporated
    The generators are of a slightly different pattern, with less of the generator in the direct flame of the burner in the 501A (on the left)
    That and a small upward curve towards the inlet and outlet connectors in the 501A generator (on the right here) contributes to less heat being conducted to the pricker control 'downstream' I'd say
    I suppose it was the case that such tweaking didn't restore confidence in the type and Coleman came out with a different design in the 502 - well, not all that different, with a strong family resemblance to the phenomenally successful grandpa, the 500 Speedmaster. Whatever, it put the Coleman 502 out in front, as it is in this photo of course
    Running now for quarter-of-an-hour and the control valve is just warm to the touch - not so the pricker valve, but at least the valve knob didn't smoulder as the 501 control knob would have this far into firing
    My thanks to Norman (Techguy) for his generosity in sending me the Coleman as a gift.
  2. OMC
    OMC United States Subscriber
    Illinois, the Land of lincoln
    John,
    Thank you, that is yet another great post. There "may" be a case to be made one might almost consider a 501A as a user. The hot valve like the 123 also like a 550 can be overcome.
    I liked the point re 502 resemblance to "older" 500. The 502 is out front but not with "newer" changes. They replaced the generator with one that is straight, cheaper to produce and easier to maintain like their "older" ones, ie on the 500.
    They replaced the burner with the band-a-blue a proven winner from their "older" suit cases. Older was better. thx again omc
  3. presscall
    Thank you OMC, always good to hear from you.
    The point you make about the 501A being almost worthy of consideration as a user stove is well-made. Certainly I've been putting it through its paces and with growing confidence that the faults of the 501 were eradicated with this variation.
    I spoke earlier about the temperature gradient in the generator being in a favourable direction in respect of inlet/control valve (cool end) and jet/pricker (hotter end) such that I gave the control valve the thumb test without raising a blister.
    The photo evidence is here, the circular generator reaching red heat over on the pricker mechanism side of the circle (right) but not on the inlet/control valve side (left)
    Jet/pricker end of the generator
    Control valve end
    Cooled down, there's the obvious contrast of heat tarnish over to the right (hotter) end of the generator and towards the jet/pricker and the untarnished generator on the left hand end in proximity to the inlet/control valve
    Reassuring evidence and yes, a user stove I reckon.
    Incidentally, looking at those photos again as I uploaded them I can see that the flame lifts off the burner at the valve side. I'm pretty sure that's something that will respond to adjustment, the jet pricker mechanism screwing into the burner mixing chamber and offering a measure of adjustment closer into the mixing chamber or further out. I've probably got it set too far out, resulting in a slight excess of air (from air inlet holes in the mixing chamber inlet manifold tube) over fuel in the mixture.
  4. Knight84 Canada
    Very nice work and post.
    Jeff
  5. scouterjan
    scouterjan Canada Subscriber
    Maple Ridge, B.C. Canada
    Great detailed post, I have a 501 as well, only fired it for a few minutes, but I really like the flame pattern way better than the 502. Thanks for sharing
    Jan
  6. geeves
    geeves New Zealand Subscriber
    Wellington New Zealand
    I wonder if you can hybrid a 501 burner into a 502 control and generator? Best of both worlds
