Arunfabs Ltd. Field Kitchen Burner 1993 Dual Fuel Petrol/Propane
Discussion in 'Military' started by Lampenkueche, Oct 31, 2015.
  1. Lampenkueche
    Lampenkueche Germany Subscriber
  2. Rangie
    Rangie Subscriber
    Caithness, Far North of Scotland.
    Hi Peter,
    Fine for a trial-run but DO NOT use this in anger! [-X
    At the very least find an olive and pipe to suit the gas compression fitting. Will cost a few cents and make it 100% safer.
    Alec.
  3. jbf
    jbf Canada Subscriber
    :idea: And post your Apfelstrudel recipe
    john
  4. snwcmpr United States
    USA
    I had look that up. I did not know compressed fittings were called that.
    Ken in NC
  5. Jeopardy
    Jeopardy United Kingdom Subscriber
    +1 on using the correct size pipe and olive.
    Very risky using a flame to test for leaks too even if you were confident that there wasn't one and it was outdoors. The heat from the flame might easily have expanded something to open up a small hole. Soapy water is a much better bet and it would show you exactly where any leak was.
    regards
