Atlas Cairo Lighter
Discussion in 'Stove Paraffinalia' started by z1ulike, Nov 7, 2016.
  1. z1ulike
    z1ulike United States Subscriber
    After posting this Atlas Cairo coil burner...
    I picked up this Atlas Cairo lighter from eBay
    The bottom has a thumb screw for adding lighter fluid
    The other screw on the bottom can be removed using a dime.
    Once removed you have a small screw driver that can be used to replace the flint.
    After fixing the wick, installing a flint, and filling with lighter fluid it works well.
  2. ROBBO55
    G'day Ben, That's a very solid,well designed lighter. Congratulations :thumbup:
    Martin
  3. SveaSizzler United States
    Tucson, AZ
    Very nice Altas collection you've got going. The ancient style decoration is classy.
    Is there much difference between Coleman gas and Zippo, and/or Ronson lighter fluid? They're both listed as ''naptha.'' I've seen some English language ads for the Imco Austrian lighter that call it a "Gasoline Lighter."
    I wouldn't try 91 octane in one, but while camping, I tried Coleman gas in my Imco and it worked OK.
    I've heard of Marines in 'Nam dipping their Zippos --on a wire -- into fuel tanks of a Jeep when lighter fluid was unavailable.
  4. z1ulike
    I'm pretty sure there's no difference at all. Coleman is basically highly refined gasoline that has had the sulfur and aromatic hydrocarbons removed. I wouldn't recommend 91 octane but not because of it's octane rating but because automobile gasoline might contain ethanol and for sure contains aromatic hydrocarbons like benzene, xylene, and toluene which are carcinogenic and produce black sooty smoke that no body needs. In 'Nam, in a pinch. O.K. otherwise I'd steer clear.
  5. SveaSizzler United States
    Tucson, AZ
    I think Zippo lighter fluid is too expensive to use in a SVEA, for instance, but possibly, if it's the same grade of Naptha as CF it would serve in extremis.
