Burmos - Unknown model
Discussion in 'Townson & Coxson' started by Admin, Oct 23, 2012.
  1. Admin
    Admin Courtesy of Iani
    This model is not particularly common, has round recess for the filler cap, not the eliptical, as usually seen on Burmos stoves. Odd arrangement for the non-return valve, unscrews from the bottom of the NRV. Still has its plastic pump cup. Spirit cup was brass plated steel, had a small hole in it, replaced with Brass, with the same markings as the original.
    1351000595-IMG_8104_opt.jpg 1351000612-IMG_8105_opt.jpg 1351000635-IMG_8106_opt.jpg 1351000660-IMG_8107_opt.jpg 1351000682-IMG_8108_opt.jpg 1351000709-IMG_8109_opt.jpg 1351000730-IMG_8110_opt.jpg 1351000752-IMG_8111_opt.jpg 1351000774-IMG_8112_opt.jpg 1351000799-IMG_8113_opt.jpg 1351000821-IMG_8115_opt.jpg 1351000843-IMG_8116_opt.jpg 1351000868-IMG_8117_opt.jpg 1351000891-IMG_8118_opt.jpg 1351000915-IMG_8119_opt.jpg 1351000936-IMG_8120_opt.jpg
  2. kerophile
    Hi Ian, Interesting stove. I have only once seen an NRV with that arrangement. It came from a 1930s Juwel No.1. Have a look at the bottom of this thread for an image:
    http://classiccampstoves.com/posts/64230
  3. Admin
    Hi Kero
    I came by one of these stoves, sometime ago. I had to take the NRV out, very very grubby, once removed. Struggled like a prat to undo it, not realising that it had to be unscrewed from the bottom end ! I think you can guess the rest.
    xx
    Ian
  4. shagratork
    Durham City, England
    Hello Ian
    That is certainly an interesting stove.
    All sorts to look at and ponder. The high tank sides with rounded shoulders - higher I think than other discus stoves.
    That non-return valve - thank goodness George remembered another like it.
    Also things like the pressed strengthening of the bottom of the tank.
    Ian - you keep turning up these interesting stoves. Well done!
