CEJN fitting strip-down
Discussion in 'Fettlers Master Class' started by presscall, Apr 18, 2012.
  1. SNOWGOOSE
  2. presscall
    Ah, Snowgoose got his reply in first. Makes sense to go for the Optimus spare, though as I noted in my original post I happened to have a Primus Omnifuel O-ring (part number 731905) - £2 from CCS Base Camp - that was also a fit.
  3. vargen77 Sweden
    What is the size on the o-rings in mm
  4. presscall
    @vargen77
    I had reason to return to this thread to consult it for repair of a fitting and noticed your post. I recommend the 'Alert' feature on the site to make sure a question doesn't get overlooked as yours was.
    I don't know the size of the O-ring, sorry. Approximately it's 6mm outer diameter and 3mm inner but there's no precision in my measurement. Primus Omnifuel O-ring (part number 731905) will work.
  5. vargen77 Sweden
    Ok thanks will check that out
  6. NP4-8-4
    NP4-8-4 United States Subscriber
    O-ring size for CEJN from USA source:
    McMaster-Carr
    600 N County Line Rd
    Elmhurst, IL 60126-2081
    Chi.sales@mcmaster.com
    I ordered the following:
    Mil-Spec Fluorosilicone O-Ring, mil-R-25988/1-006
    Many thanks to Presscall for his [usual] detailed photo-essay on how to dismantle an old style Optimus Nova pump with a CEJN fitting. I had used this stove on a backpacking trip to Rocky Mountain National Park this past summer. Towards the end of the trip I began to experience difficulty with the CEJN valve sticking "open" so that fuel would leak out of the filling. Searching the site for repair ideas I came across this thread. Presscall's suggested use of a Primus O-Ring and the accompanying photo made me think that the Primus O-Ring, in comparison to the Nova's CEJN O-Ring, looked similar in size to the O-Rings I purchased from McMaster-Carr to service my Coleman 222 lanterns. I finally had some time to fettle the fitting this evening. Dismantling the CEJN fitting and comparing its O-Rings with the McMaster-Carr O-Ring revealed a nearly perfect fit. Although the Nova's rings were intact and still pliable, I replace them nevertheless. Just fired the stove and it functions as it should. Perhaps it was the MSR mineral oil I slathered on the rings that restored operations to normal. In any event the stove runs fine with the O-Ring noted above.
    McMaster-Carr's prices seemed reasonable and they shipped very quickly.
  7. presscall
    @NP4-8-4
    I'm pleased your repair was successful and glad to have assisted with the write-up.
    That's a really helpful reference for the O-ring source.
