Coleman 502 - 1972
Discussion in 'Coleman No:502' started by idahostoveguy, Aug 14, 2009.
  1. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    Some pics of a Coleman 502 Sportster that I recently fettled.
    1250214332-coleman502_1.jpg 1250214349-coleman502_2.jpg 1250214365-coleman502_3.jpg 1250214383-coleman502_4.jpg 1250214396-coleman502_5.jpg 1250214413-coleman502_6.jpg
  2. CWilkins
    CWilkins Subscriber
    New Jersey, United States
    Hello,
    Hey what did you need to fettle to get it working ???
    Chuck
  3. idahostoveguy
    Potato Country USA
    I wish I had a before picture...
    I had to:
    1. Clean the generator out. It was completely clogged and gummed up with black tar.
    2. The knob and valve were stuck. Fixed that with a soak in some solvent.
    3. Burner and manifold were a mess. Gummed up and had rust all over. Wire wool on each burner ring piece.
    4. Fuel pick-up tube needle was stuck. Cleaned it up.
    5. Cleaned out the tank.
    6. High heat painted the burner, valve body bracket, and manifold.
    7. Citric acid on the brass pieces including the generator, which went from black to shiny brass.
    sam
  4. endy Belgium
    Norway, Westcoast
    Hello Idahoestove
    I have the same stove as yours. Bus the flame looks less powefull. I tried to clean the generator with citric acid but the spring inside the generator still doesn`t come out of the tube for better cleaning. Is the spring fixed in the tube? How can I clean the generator? New generators are very expensive here in germoney.
    regards: Endy
  5. bajabum
    California Coast
    To remove the spring from inside Coleman generators, you need the special tool.
    Take a heavy duty paper clip, straighten it out, then put a 90 degree twist on the end, about 3 mm long.
    Screw the 'special tool' into the genny and then pull hard..
    It should pop out!
  6. idahostoveguy
    Potato Country USA
    Hey, Bajabum!
    That's my company proprietary secret tool! It's obvious I have a corporate spy living with me! ;)
    Carburetor cleaner will also help loosen things up too. I let my generator soak in a solution of kero, white gas and carb cleaner for an hour and it was loose enough to pull out with my 'proprietary tool'. :)
    sam
  7. bajabum
    California Coast
    Yeah, I found an old Coleman brochure on the site that showed Original tools for generator dissasembly. The paper clip tool is a cheaper fix ! :mrgreen:
    And they work well!!!
