Coleman Apex
Discussion in 'Other Models' started by presscall, Dec 23, 2011.
    Early model Apex (1995), dismantled for servicing
    The valve block pricker eccentric spindle is the rod projecting at the right and an 'O'-ring provides the seal. It was sound and a dab of silicon grease ensures smooth operation
    The 'O'-ring providing the inlet flexi-hose connector seal appears to be a weak link with these stoves, judging by CCS member feedback.
    No problem when the seal is new, but it soon degrades because too much is expected of it, with the insertion and removal of the fuel tube each firing. Two 'O'-rings should be better I reasoned
    The extra bulk of two 'O'-rings leaves the retaining nut standing proud, but tightening it between finger and thumb when the flexi-hose fuel spigot is inserted compressed the rings and makes the seal more secure
    The other issue I have with the stove is the 'O'-ring seal on the stove pump to stove bottle joint.
    On the left is a new one out of the spares kit; centre is one that's been in use for a short while; right is one that's been in use for some time
    That yellow latex skin on the 'O'-ring easily rubs off ...
    ... and can all too easily end up in the pump
    A speck in the fuel pick-up elbow blocking the pin hole venturi (it contributes to atomisation of the fuel for the Coleman easy-starting capability) would have prevented operation
    Solution to the self-destructing 'O'-rings, a more substantial item from my stock
    Flexi-hose fuel outlet tube protection sleeve, has a useful parking space on the pump to get it out of the way of the burner heat when the stove's in use
    Reassembled, and confident there'd be no fuel leaks, stove fired up
    A characteristic of the stove seems to be a 'chugging' sound in use.
    It is I think due to the fact that unlike the more orthodox Coleman stove without a remote fuel source, the arrangement at the pump of the inlet tube above the surface of the fuel and a pinhole opening for fuel at the plastic 'elbow' joint in the fuel allows for no manual switch-over to neat fuel when the stove's warmed up.
    So it's a lean enough fuel mixture for an easy start without flaring but is a shade too lean once the stove's got hot.
    Testing my hypothesis by running the stove on butane fuel (Frankies, Mods and Hybrids Forum) results in no such 'chugging'
    Coleman Apex on butane fuel
    Something I've yet to try, but the butane conversion flexi-hose can take a Primus Ominfuel pump and fuel bottle. I expect that too would eliminate the chugging phenomenon, though flare on start-up would be substantial.
  2. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    Hi John,
    Beautiful tear down and presentation. Thirty-some-odd parts is quite the number.
    What I've found on these stoves after replacing generators, jets, O-rings, etc., I found that by only slightly opening the fuel valve on the pump, the chuffing stopped. It must be getting too much fuel to vaporize, or over-pressurized, or something akin to that. Opening the valve, say, 1/16 turn or less seems to stop the chuffing. I have three of these and it does it on all three. Age of the stove maybe? Worn main fuel valve? Cold weather? Still guessing.
    sam
  3. mr optimus
    Hi John brilliant documented break down and service of the early Apex,i wonder waht purpose the latex skin on the pump O'ring serves,in my opinion it is a hinderance as once it breaks down as you pointed out if it does find its way into the pump and gets into the fuel pick up then theres a problem with easy starting
  4. toonsgt
    The chuffing is caused by too open a path for fuel to return to the bottle when it hits the hot generator. Closing the valve as stated slows the fuel rate both ways and smooths things out. If you put your ear to the fuel bottle while it's running(don't burn your hair), You hear a ball check(?) clicking in sync with the chuffing. It's the cost of the simple operation design of the pinhole vs relatively huge air tube and chuffing on a full open valve nearly always happens on mine. These stoves rely on back pressure to shut off the atomization/instant light feature. When cold the volume going through the fuel tube is quite substantial and pulls air down the tube. Once warmed up, the flow reduces dramatically and the pinhole can then NEARLY keep up on it's own. When it can't, it chugs.
    Thats my take on it.
    Mike
  5. idahostoveguy
    Potato Country USA
    Very good take on it Mike. I'm figuring that you are right. The fuel tube is relatively large and has nothing inside of it like MSR stoves' cleaning cable. I've had occasion where my MSR stoves chuff when I don't have the cleaning cable inserted (maybe during cold weather?). Perhaps if there was something inserted into the Coleman tube to take up most of the space, the chuffing would not occur. An experiment waiting to happen...
    sam
  6. Murph
    The yellow coating is to show that the rings are Viton, and NOT neoprene, helps in industrial settings to tell them apart in shops where both are used.
    Murph
  7. idahostoveguy
    Potato Country USA
    They also do Viton in brown too.
    sam
  8. Big BTU
    Big BTU United States Subscriber
    Hawaii
    Wow John,
    I thought I liked taking things apart! LOL. Great job as always.
  9. presscall
    I think the 'easy start' capability would be lost, and I expect that it's to facilitate that that the fuel hose is so short. Any longer and the atomised fuel would condense and flare and mess up the easy-starting capability.
    Mike's explanation for the 'chuffing' sounds good to me. I can visualise that tube to the pump/stove outlet having a succession of air bubbles in the liquid fuel, just as the pickup tube in an aerosol can does.
    To check out the stove on a wholly liquid feed I connected a Primus pump and fuel bottle to the pre-heated stove. Result was a steady, powerful flame with no 'chuffing'
  10. weasel Canada
    Wow am I glad I found this. Just bought one today and am planning a teardown. Need to find me some o-rings. I have a couple, but will have to check for size.
  11. blue_ranger
    Excellent write up, thank you for sharing.
    I've got one of these I bought new in '98. I tested it recently and found the pump assembly leaks when I turn the fuel valve on. My guess is that the o-ring needs to be replaced. Any thoughts on where I can find a new one? My local Ace doesn't have anything that small, and a replacement was not included in the service kit.
    Thanks!
  12. bajabum
    California Coast
    Try your local Harbor Freight, they have Nitrile AND Viton O ring sets, pretty cheap...
  13. skorpiius Canada
    I'm curious if anyone who has used or uses both the Apex I/II and the 550 could give a comparison. I had the idea that the Apex might be better because you could fully windscreen it without worrying about overheating an integrated fuel tank, but after using the 550 this weekend the add on burner-only windscreen was completely fine in 50km/hr winds, and probably wasn't even needed as the burner of both models has great built in wind screening. Thoughts?
