Coleman Twin Burner (Kerosene) (Made in Australia)
Discussion in 'Other Models' started by Tony Press, Oct 19, 2015.
  1. Tony Press
    I finally got around to fettling this unusual stove, made under licence in Australia.
    I will post all of the stove as I got it, but I doubt the "suitcase" is either a Coleman, or originally for this stove.
    It is kerosene, and has Optimus fittings:
    One burner is SVEA, the other Optimus:
    Brass Coleman tank:
    The bits:
    Cleaned up the rust from bits and pieces:
    There are a couple of odd things about this stove. The left hand burner is mounted higher than the right one (you can see the welded positions of the holding plates in these two photographs:
    Here it is in operation:
    And here in the suitcase it came with:
    The suitcase is most likely made in a workshop rather than factory-made, and probably not for this stove. You can see in the above photo that a piece had been cut out in order to make easy access for the pump. I added a couple of other small cuts to allow the regulators to sit more comfortably:
    The pot rest is also very much aftermarket. I think this stove would have had a pot rest that was hinged to the stove.
    As it came:
    As this is such an unusual stove, I wanted to keep it as close to its found condition as possible: I cleaned the stove, painted the drip tray, and treated the whole lot with car wax. I repainted the black suitcase.
    This stove will be my workshop stove for the time being. It really is heavy with the suitcase, so I'll leave it set up.
    Any help with identifying what model this might be will be greatly appreciated.
  2. kerry460
    kerry460 Australia Subscriber
    Tasmania , Australia
    Tony , i like it .
    but i think it may be a Heinz :)
    keery
  3. z1ulike
    z1ulike United States Subscriber
    Some of the most interesting stoves come out of Australia. Are you running this thing on Coleman fuel or kerosene? It looks like a domestic stove that someone built a suitcase for. They did a fine job of it too judging by the photos. Heavy but really sturdy.
  4. OMC
    OMC United States Subscriber
    Illinois, the Land of lincoln
    Tony :thumbup::thumbup::thumbup::thumbup::thumbup:,
    Excellent post and stove: it's unique and it's held my interest since you 1st introduced it.
    We've not yet seen anything exactly like it but it's comparable w/a few Coleman models (US & CA). I like yours :mrgreen: and consider it for the best of the lot. +1 it strikes me as odd having burners at 2 heights, is that possibly by-design? (if so, unique to this stove?, a design that fizzled but I wonder what was the "concept"? /what were they thinking...).
    Re the grate: Of those comparable/similar models, almost all, have different grates. With your grate sitting loosely atop enamel finish I too wonder if it's original but btw the Canadian 381B 's grates set atop enamel like yours does (not the gratest setup). http://tgmarsh.faculty.noctrl.edu/colecastove.html
    thx omc
  5. z1ulike
    It runs on kerosene. I'd have known that if I could read. Duh...it's in the title.
  6. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    That's fantastic, Tony! I love the case and the kero burners. I like the combo of Coleman and Optimus and Svea!
    Is the whole thing, together, in the case, pretty heavy? The case doesn't look too bad for home made.
    sam
  7. scouterjan
    scouterjan Canada Subscriber
    Maple Ridge, B.C. Canada
    WOW thats very interesting. Tank looks like its from a Canadian 6J or a 4M. I guess the best part is it makes blue flames
    Jan
  8. Tony Press
    @idahostoveguy
    Sam, the whole thing, in the suitcase is heavy. I haven't weighed it yet, but I will.
  9. threedots New Zealand
    Kapiti, New Zealand
    Hello Tony.
    A nice practical stove.
    That SVEA #1915 burner is very good burner as well.
    The burners themselves are different heights(being different makes) I think.
    The mounting tray may have been altered to accommodate the differences.
    Cheers, John
  10. Tony Press
    Having recently seen another one of these I can confirm two things:
    1. It is called a Coleman Chef, model number 336 in the Coleman Thomas catalogue from the early 1950s.
    2. The pot rest is probably original to the stove.
  11. OMC
    Hello Tony,
    Thank you for the updates including all important "ID" it was elusive but now with your info fellow stovies can find their info right here and more details might emerge for an excellent stove.
    Canada !! You established that connection above w/image & text, thank you, while I'm here, here is (searchable) text re that: No. 336
    "Made in Australia by arrangement with
    The Coleman Lamp and Stove Company Ltd.
    Of Canada
    Proprietor of the Registered Trade Mark No. 67296"
    I said above I view yours as best of the lot and with your info was happy to see another example, coincidently it just posted onto the internet yesterday! A No. 336 Table Stove, it's label includes "The best of it's kind" :thumbup:. thx omc
  12. Tony Press
    @OMC
    The one on CCF, which you link to above, is the one I saw on the weekend...
