COMPANION (SVEA) with Roarer Burner
Discussion in 'Companion' started by ROBBO55, May 21, 2015.
  1. ROBBO55
    The tank is stamped COMPANION STOVE with the SVEA logo.
    The spirit cup has COMPANION SVEA PATTERN stamped in the bottom (other Companions I have seen do not have SVEA PATTERN).
    The tank filler cap has COMPANION stamped in one side.
    The pressure bleed is cast with COMPANION on one side and SVEA on the other (raised letters).
    The burner has COMPANION SVEA cast in the top (raised letters).
    The leather pump cup assembly is a riveted construction. The assembly is not fixed and slides on the shaft allowing air entry on the up stroke. It is held on the shaft by a brass nut. The NRV is standard.
    The flame ring was missing.
    Martin
    1432194708-P2_opt.jpg 1432194727-P3_opt.jpg 1432194803-P4_opt__1_.jpg 1432194833-P5_opt.jpg 1432194857-P6_opt.jpg 1432194883-P7_opt.jpg 1432194903-P8_opt.jpg 1432194923-P9_opt.jpg
  2. Tony Press
  3. Sedgman
    Rainbow, Vic, Australia
    very well restored and looks a million dollars. the Companion varieties are a step closer to a resolution too. :thumbup:
    Iain
