COMPANION with Silent Burner (unused)
Discussion in 'Companion' started by ROBBO55, Jul 19, 2015.
  1. ROBBO55
    The stove came in a cardboard box with no markings. There is a shadow indicating a full sided label was attached at some time. I believe the box to be original as it is a neat fit and similar in construction and size to other marked stove boxes I have seen.
    The instruction manual is a generic COMPANION instruction for use as previously listed here http://classiccampstoves.com/threads/the-companion-stove.245/
    The tank is stamped COMPANION STOVE with the COMPANION logo.
    The spirit cup only has COMPANION stamped in the bottom.
    The tank filler cap has COMPANION stamped in one side.
    The pressure bleed is round (13 mm dia) with no markings. Whilst there is no marking to prove it is original, the condition of the pressure bleed is consistent with the corrosion on the rest of the stove. Indicating it is original.
    The burner has no markings but a paper label is attached COMPANION STOVE trial burned and tested.
    The Outer Cap has no markings but has a notch in the rim similar to other marked Companion caps.
    The Inner Cap is stamped COMPANION BRAND.
    The leather pump cup assembly is a riveted construction. The rivet is steel where the rivet is brass in other versions I have. The assembly is not fixed and slides on the shaft allowing air entry on the up stroke. It is held on the shaft by a brass nut. The NRV is standard.
    Martin
    14.JPG 2.JPG 3.JPG 5.JPG 6.JPG 7.JPG 8.JPG 9.JPG 10.JPG 11.JPG 12.JPG 13.JPG
  2. Tony Press
  3. Sedgman
    Rainbow, Vic, Australia
    I like the accompaniments as well as the stove. :D/ All very ridgy didge (aka true, original).
  4. shagratork
    Durham City, England
    Martin that is a very nice stove.
    Apart from the manufacturer's trial burn, it has never been used.
    Everything is well stamped with Companion and you even have the printed instructions and the original prickers in their paper sleeve.
    All contained in the original box.
    I may be wrong, but I don't think there will be many other Companion stoves in the same condition.
    A very desirable kit.
  5. abbahco1
    abbahco1 United States Subscriber
    Cambridge, MA, USA
  6. ROBBO55
    Thanks for the comments.
    Iain, it’s another piece to the puzzle regarding Companion stoves and their changes. :doh:
    Trevor, it is a nice addition to my growing collection of stoves and it will stay in once only test fired condition whilst I have it.[-(
    Peter, thanks for the link to the box label. It is a part of the site I have not spent much time in (but it looks like I need to). I will print a copy and keep it with the stove.:lol:
  7. abbahco1
    Cambridge, MA, USA
    Hi Martin, The one change that was made to the Companion stove from its Svea model was the design of the pump leather assembly - often riveted rather than the leather being sandwiched between a brass insert and a steel nut (which makes replacing the leather practically impossible). However, some Companions used the Svea (and every other manufacturer's) arrangement, so it's not rendering your stove any less authentic by replacing it when you need to.
    I was recently in rural Victoria and there were Companion's in evidence everywhere. Not surprising as they were made in Melbourne. Yours is a real find, though.
  8. ROBBO55
    G'day Peter, Your not wrong. I tried replacing the leather on one by opening the old rivet. It just fell apart. Since then I have replaced the pump leather by making a new rivet on a lathe.
    The other change is the amount of branding on the stove and components. Svea was removed first then Companion removed from components. The burner and the outer cap is not branded on this stove. Whilst other stoves i have are branded Companion.
    Thanks
