Companion
Discussion in 'Companion' started by Archivist, Apr 30, 2008.
  1. Archivist
    Archivist United Kingdom Archivist
    Courtesy of "Handi" Albert White, Queensland, Australia
    Australian stove made under license from Sievert.
  2. vic Australia
    Hallam Australia
    Just got hold of a Companion stove it came with a cone full of holes which sits on top of the burner. What is this for? Also it will start, but after a few pumps it cuts off.
    Any info on these two question as I am new to this stove game.
    vic
  3. -/- Denmark
    To the first question:
    It's a heat spreader. holding the heat of the stove there and radiating it off instead of the heat "escaping" upwards with the flame.
  4. Wim
    Wim Belgium Subscriber
    Hi Vic, could you be a bit more precise re the cutting out? It could be you're loosing pressure through a bad seal on the fillercap (if it is hard, it needs to be replaced) or via a leaking NRV valve (sits at the bottom of the pump). If it is the NRV also fuel will be leaking out (if the level in the fount is high enough) through the pump.
    Wim
  5. vic Australia
    Hallam Australia
    thank sorry about bad discription but thank you for help
    vic
  6. vic Australia
    Hallam Australia
    thank you for your help Ican see how it works
    vic
  7. clancambo
    clancambo Australia Subscriber
    Bayswater, Melbourne, Australia
    Hi Vic
    Have a look on this site for fire bowls and heaters. The cone is part of a heater. Usually has a polished aluminium reflector behind.
    Ian
  8. -/- Denmark
    It dont have to be!
    The domes were/are sold seperatly and transforms a standard stove into a crude room heater.
