Duo-Burn 2-pinter, fixed leg, lipstick burner
Discussion in 'Falk, Stadelmann & Co Ltd' started by presscall, Jun 15, 2011.
    Brian Miller has this model pinned as a cheaply-produced, underpowered and somewhat ugly compromise in a post-war Britain restoring it's economy by exporting all the good stuff
    kaw550red's Duo-Burn
    Compelling arguments, but let's take a closer look at the stove. Looks ok from some angles, with a rather handsome silent burner converter cap in brass, not branded Primus (or Duo-Burn, but I'll take a look at that later)
    Brian's attention focused on the burner, which is certainly something of an oddity, as a half-pint-stove-sized lipstick burner with a 100-sized burner bell and an adaptor to screw it onto the 2-pint tank's riser tube
    Top's the Duo-Burn burner components, middle's from a Primus 96 (with BernieDawg silent burner converter cap), bottom's from my pre-1911 Primus 100 with a modern silent burner converter cap
    Putting those burners and components into context with their stove tanks
    Brian suggested the Duo-Burn's vapouriser tube was RM/Thermidor produced. Quite possibly, but handling the two together, there are detailed differences in tube contours - other than the obvious one of the fitting arrangement
    The Duo-Burn comes with a substantial roll of gauze installed
    Ok, back to the aesthetics of that burner and its performance on the stove.
    It certainly looks somewhat inadequate ...
    ... but starts to improve when the rest of the components are added
    I said earlier that I'd take a closer look at that silent burner converter cap (on the left, Primus equivalent on the right)
    Detailed differences, not least in diameter and height, suggest the brass one's not of Primus make
    In terms of performance, it's no worse than that of a Primus 100, which admittedly is itself not up there with the more powerful stoves, having a 0.23 diameter jet orifice (same as that of a 96 lipstick burner). Got going pretty well though
    A few more pics to follow shortly ...
  2. presscall
    Of course, with that 100-sized burner bell I just had to try out the Primus's roarer burner plate.
    The Duo-Burn certainly gave it a good workout
    Back to the silent burner converter cap, working well on a 'tea test'
    Other possibilities. Duo-Burn burner bell and converter cap and roarer plate on a half-pint Thermidor
    Not a good idea. The radiant and conducted heat from that extra mass of metal got the tank uncomfortably hot.
    Those Duo-Burn aesthetics again. That 'step' between the scrawny vapouriser tube and the riser tube from the tank is what robs its looks. How about a Primus 107-style windshield to disguise it?
  3. Dutchmike Netherlands
    That brass de-luxe windshield sure restores some balance estheticly, John! I sniff a demand for said shield....and not only from Primus 57 and 107/110 owners!
    Regards, Mike
