Gas Burner EXPRESS
Discussion in 'France' started by Lampenkueche, May 8, 2016.
  1. Lampenkueche
    Lampenkueche Germany Subscriber
    Just arrived a Gas Burner from France. Got a new Seal in the Pilot-Flame and the Gas Connector was modified a little bit.
    Everything looks OK and so I give him Propane with 1,5 bar Pressure and Light it up. Wow - thats nice Stuff for my Kitchen.
    Cheers Peter
  2. presscall
    Excellent, Peter.
    I recall a few of us spotted that up for sale as a mystery burner and it's a real pleasure to see the video as a result of your effort getting it to work.
    Although aesthetically an eye-catcher, it's actually a really functional and obviously effective burner.
  3. Wim
    Wim Belgium Subscriber
    Hi Peter, looks like this is a hot one!:lol: Are you sure propane is the correct type of gas for it? It seems to over power the burner. Can you regulate the funnel-like valve just behind the valve block? If you can open it a bit more the flame at full power will get more air. It looks like this burner can easily be used for a big wok! The pilot on it's own looks capable to get a kettle to boil:D/. Nice score, congrats!
    ATB,
    Wim
  4. kerophile
    Hi, looks rather like a butane fuel stove running on propane. Those yellow flames indicate a fuel rich mixture almost as soon as you increase power. The flame pattern at the low power setting look to be a perfect atmospheric blue, and quite powerful enough for most purposes.
    Good looking burner/stove
  5. geeves
    geeves New Zealand Subscriber
    Wellington New Zealand
    Its probably jetted for a domestic supply ie mostly methane
  6. Lampenkueche
    Propane is the chepest what I can get here, but in France its almost Butane. The Burner stands
    under the Blow-Lamp-Section, so maybe it is for an glowing Oven or something else.
    In my Kitchen its a hot Fireplace...
    Playing with an other Cam Mode...
    Pot Stand is from the small 15 L BVB and the Coffee Water boils in Seconds. :-))
    Cheers Peter
  7. kerophile
    The flame pattern from the multiple burners is almost jewel like.
    A beautiful display, and obviousy very powerful.
  8. Lampenkueche
    Yes looking the Flame is great and the Temp in the Room is rising. Puting a handfull of white Bacon in the Pan
    and roasting some Sparerips.
  9. Wim
    I see you like the Turck steel frying pan, it is my favourite for living history use! Very good quality.
    Best regards,
    Wim
  10. Doug L
    New York
    Wow that vid was impressive.
    Yes I remember seeing one here titled What Is It ?
