Gas Pak butane stove
Discussion in 'Other Brands' started by presscall, Apr 30, 2013.
    Pineapplerose found this one and mentioned it here
    Gas Pak
    Sooty's kindly made me it's new custodian and here are a few initial shots after taking delivery of it today.
    Fuel is from a Ronson blowtorch, now obsolete as a fuel source but that's an unused can and the Gas Pak will enable me to refill the cartridge - but more of that in the 'Frankies, Mods and Hybrids' column in due course. Svea 123 included for size comparison of course
    1367360191-1.JPG 1367360201-2.JPG 1367360209-3.JPG 1367360217-4.JPG 1367360230-5.JPG 1367360240-6.JPG 1367360249-7.JPG 1367360256-8.JPG 1367360264-9.JPG 1367360274-10.JPG 1367360284-11.JPG
    Thanks again Sooty!
  2. pineapplerose
    pineapplerose Australia Subscriber
    Underdale South Australia
    What a smarty you are, I am so pleased to see it working, that is quite a flame thrower. Does it need a simmer plate to disperse the heat, looks like it will burn the arse out of the coffee pot. It's former life may have been in a dental technician set up.
    If it had stayed with me it would have just ended up being used as a prop for photography, it is such a lovely shape.
    cheers Sooty
  3. Murph
  4. teletim United Kingdom
    Looks heavy with all the brass and steel?
    Powerful little thing.
  5. hikin_jim United States
    That's quite a flame it has there! Surely there are butane canisters compatible with it? Perhaps at a Tobacconist?
    HJ
  6. Vintagetwinshock United Kingdom
    G'day sootyfingers,
    I never thought I'd see the day when your old gas pak made it to these shores, with John, it's certainly in good hands, he's sussed a way of re-filling his cartridge, whether it's of a type which is obtainable out of a tobacconist is something I have no knowledge of.
    Looking at it's flame, it's similar to one thrown out by an old rechaud bleuet can gas stove, looking at it, it's quite likely to have been popular with backpackers, scouts, cadets & cyclists.
    Definitely a rare beast, best wishes=Johnno.
    If in doubt, brew up.
  7. presscall
    Working week over, I've had a bit more time to tinker with the stove tonight, which included looking more closely at the hose connection and fuelling arrangement, hose disconnected here
    The Ronson butane cartridge I've been using is only an approximation to the long-obsolete Australian original brand. It takes the stove's fuelling hypodermic needle, but the black sheet metal spacer mounted on the control valve ...
    ... doesn't match up to the dimensions on the Ronson cartridge, so doesn't offer any support
    Pity, because removed from the control valve it fits the Ronson cartridge's support boss
    By unscrewing the needle injector from the control valve the spacer/support can be removed
    There's a rubber seal inside the needle mounting nut ...
    ... which makes a seal even hand-tightened
    Impracticable as a fuelling device without a spacer/support, since it's just too vulnerable to knocks
    Constructing a taller spacer/support would be one option to retain the needle fuelling from a Ronson cartridge, or, using the control valve taken from one of those Chinese-sourced flexi-hoses and control valves to fit screw gas cartridges, bought cheaply as a spare for the Chinese TK-something stove
    To make use of that screw-fit control valve I'm relying on a useful feature of the Gas Pak, which is to use a couple of these ferrules ...
    ... to make a secure, gas-tight connection at the control valve and stove
    By soldering a small length of brass tubing to the screw-fit control valve's hose barb, I've bulked out the diameter of the control valve fitting to suit the Gas Pak's hose
    Alternative fuel source, but with the conversion readily reversible to install the needle injector control valve to keep this old butane stove original and authentic
    A side benefit I had in mind was to create a refuelling rig for the now-obsolete Ronson gas cartridges
    It lets me keep another old-timer from the tool cupboard running and that's good because there's nothing quite like the Varaflame feature for achieving the optimum size of flame to heat soak a (small) component for soldering or sil-brazing and simply feed the solder wire or brazing rod into the joint
  8. presscall
    Tried my hand at producing a waterslide transfer, tidying up an image of the worn example on the stove ...
    ... to get onto a sheet of waterslide transfer paper for a laser printer
    Off with the old ...
    ... and on with the new
  9. geneislucky United States
    Really, just too cool. Great job.
  10. shagratork
    Durham City, England
    Ian, the waterslide transfer looks great, especially on the stove.
    You mention that you used a laser printer.
    After you printed did you coat the transfer with anything or is the laser printing stable?
  11. presscall
    Hi Trevor.
    A feature of the laser printing transfer (decal) paper and a laser printer is that there's no need to seal the surface with an acrylic varnish as is the case with the bubble-jet paper printed version.
    Same end result in terms of durability and finish I expect, but I'd the use of a laser printer so I went for that option.
