Juwel-6B
Discussion in 'Juwel No:6' started by multi-cho, Sep 24, 2014.
  1. multi-cho Korea, Republic of
    Dear Mr. Ian Hunter
    wow ........ !!!!!!
    I found a long time, wanted to see a stove.
    This version is considered as reviews about the possibly Juwel 3p.
    Because it resembles Juwel-5b / Juwel-6b and the pump.
    However, if the same will be referred to 3b stove legs.
    Thank you for showing a very old stove
    First, you need to think two things to restore.
    1 Specification of the cap
    2 fuel cap air valve
    Then you see the data record.
    1 of cap Dimensions: Height 26mm / Top width: 22 mm / bottom width: 34mm
    Hole size: 1.2mm /
    The spacing between the hole and the hole: 2.1mm
    The thickness of the cap :: 1mm
    Number of Holes: 42ea
    Hall singular: 5
    2 air valve: GB Juwel is consistent with other products (photos)
    1412381796-__________juwel_5_6_out_cap.jpg 1412381814-__________juwel_5_6_cap_2.jpg 1412381836-__________BARTHE_3.jpg
  2. multi-cho Korea, Republic of
    This cap is a Juwel-6b technical museum in Sweden.
    This seems to be best way that can help you in a foreign country. I'm sorry I can not give more help relax
  3. multi-cho Korea, Republic of
    Mr. Ian Hunter
    I do not know whether this answers your question.
    As shown in illustrations a long slender than juwel-6 in the early days of the pump juwel-3.
    In comparison photos, look at the leather backing
    Is larger juwel - 6.
    Attached to-check valve juwel-6 stove
    There are four types in my experience.
    1412578940-____________________2.JPG 1412578963-____________________1.JPG 1412578976-_____________26D6_1.JPG 1412578988-_____________24D6_1.JPG 1412579009-__________________________002_1_.jpg 1412579025-____________________3.JPG 1412579047-_________________2_1.JPG 1412579069-__________IMG_2716_1_.jpg
