Hello - I acquired my second M-1950, a Rogers 1951, at an antique store recently. Needed the usual NRV pip, pump washer, etc, all nicely supplied by Old Man Coleman. Also a new control knob as the old one was in quite bad shape. As you can see from the pictures I had to wrap the valve body with 3 or 4 layers of fuel-proof teflon tape, without which the valve would sit so low that the control knob had in the past actually dented the tank. Also note from the picture that the burner sits at a bit of an angle. The valve now sits tightly in the font with room for the control knob, without any leaks, and the stove burns with a clear blue flame (should have added a flame shot). My question is - will this remain leak-proof and safe with these layers of tape? Thanks for the help. Tom
Looks to me like you are missing the valve wheel stop pin from the burner shroud. The previous owner may have broke or cut the stop pin off. Only time will tell if the Tape fails. The red valve knob will touch this pin when at full closed to full open. I do have a few stoves that the valve entered the tank more than I usually see but those are working just fine.
@HercL4D2 - Sharp eye! You are correct, it is missing, and yes, previous owner. I have a manual for the M-1950, so know the positions for off, light, run. I have a friend who is good at brazing, and will have him make the repair. As you said, I'll keep an eye on the tape. Thanks! Tom
@Greeley you may be able to Get a replacement here. http://go-armynavy.com/military-sur...itary-replacement-burner-shield-assembly.html and here. http://www.oldcolemanparts.com/product.php?productid=1112&cat=&page=1
