M1941? date 1944
Discussion in 'Military' started by nmp, Jan 8, 2016.
  1. nmp
    nmp United Kingdom Subscriber
    Carshalton
    image.jpeg image.jpeg image.jpeg image.jpeg I found this recently not sure if it's 41 or a 42.
    The funnel,original fuel cap and tools were missing but it's in pretty good condition.
    I stripped the burner right down and replaced the graphite seals with new made from graphite tape from Fettlebox.
    I was looking for an NRV Pip to replace having done some research on the forum but discovered the ball bearing and locking pump seal arrangement.
    I should add that it's got a brass tank three legs and is marked US Coleman 1944.
    The container is painted and corroded and the whole thing has a used feel about it which I like.
    I may clean the container so it could be used for cooking.
  2. HercL4D2
    HercL4D2 United States Subscriber
    U.S.A.
    nHard to say on the date. That is a Coleman design 520 stove. The Coleman manufactured stoves had 4 legs and used brass and stainless steel for the tanks. AGM also manufactured the same stove only with a Brass tank and 3 legs. Brass tanks were painted green and have the same label. But the valve is different than the Coleman manufactured stove. Threads are of a different pitch. AGM brass tanks had a flaw in manufacturing that caused the tank to develop vertical fractures. Coleman Valve body also had a patent or part number, AGM did not. There were only 1000 of these Coleman stoves made in 1941 and they had steel tanks. Brass were made in 1942 and during the remainder of the war. It is unlikely that AGM continued to produce any more after the end of the war as it was a Coleman patent. The date on the stove only Shows the date it was manufactured not its classifacation. Id be willing to say this is a 520 pocket stove of the M1942 class and manufactured in 1944 by AGM (American Gas and Machine ) However, some of these stoves were produced in the UK after the war ended. Seems Coleman had a plant in the U.K.
    What has puzzled me is that if only 1000 of the Coleman stoves were made in 1941 then when did that happen ? After Dec 7th 1941 ? And were those considered as M1941 520 stove rather than an M1942 520?
    AGM manufactured M1942, 3 Legged
    Coleman 4 legged
  3. Wim
    Wim Belgium Subscriber
    Hi Hercl, thought you might like to know these 520s were also manufactured in Belgium in 1945. Both Tracer and I have one, and I've seen another one but can't remember who owns it. The info on the stove is in french.
    Best regards,
    Wim
  4. HercL4D2
    U.S.A.
    M1942
    I did not know that. Looks like we Americans left a lot of stuff in Europe. Looks like old man Coleman got around.
    I found a site that shows COLEMAN M1941 SQUAD STOVE, dated 1944 and never been lit.
    http://www.usmilitariaforum.com/for...1263-stoves-m1941-m1942-sing-dbl-burners-etc/
    I suppose I will have to post my M1942 AGM 520 Frankie stove that had a vertical cracked brass tank.
  5. nmp
    Carshalton
    Hi hercl and Wim.
    Thanks for more background .
    This one is marked is in fact marked Coleman and has a patent number on the valve body so a Coleman manufactured stove ? Dated 1944.
    Nick
  6. HercL4D2
    U.S.A.
    Yep just like this one. A 3 legged Coleman with numbers on the valve body. U.K. made?
    This is the first time I have been made aware of a 3 legged NON AGM Coleman stove with patent numbers on the Valve Body. You may have found a holy Grail.
  7. nmp
    Carshalton
    Where is the date usually on the container? Reading other posts and the link you sent they were dated as well?
    I did find a set of instructions for this type of stove but passed them on to Shagratork as I did not have this type at the time! Maybe I will ask him to scan them for me now.
    Nick
  8. scouterjan
    scouterjan Canada Subscriber
    Maple Ridge, B.C. Canada
    I have a 4 leg Coleman 520, its date stamped on the side of the font, never noticed a date on the canister
    Jan
  9. HercL4D2
    U.S.A.
    Some of the containers have no dates on them. Some of the stoves were packaged and shipped without containers. The date on the container normally is not tied to the date of the stove. The container date will normally be on the smaller of the 2 containers, the top one. These stoves have generally been handled by an assortment of people and containers were obtained some time later. My containers for the 520 have no dates.
  10. nmp
    Carshalton
    Just found the date of the bottom of the larger part of the pot. Marked
    US C M MFG.CO 1944
    So it matches the stove!
    Nick
  11. nmp
    Carshalton
  12. scouterjan
    mine only has the top canister, its held on by spring clips on the uprights
    Jan
  13. Rangie
    Rangie Subscriber
    Caithness, Far North of Scotland.
    Do these beasties have steel or brass bases?
    Alec.
