Making a better 8R SRV
Discussion in 'Fettling Forum' started by Peter.C, Dec 28, 2016.
  1. Peter.C Australia
    Australia
    Hi guys my Christmas present 8R rebuild hit a bump today.
    I went to replace the SRV pip with a fettle box replacement but found it always leaked under pressure (Hot water method). I found that the pip being 4.5 mm diameter was moving in the hole which measured at 4.9 mm causing it to move forward of the seat.
    I remachined a new one with a 4.5 mm seat hole.works like a charm now.
    Regards Peter.
  2. Tony Press
    Excellent! :thumbup:
  3. Spiritburner
    Was that a Fettlebox NRV pip? They are available at 4 & 4.5mm. The SRV pip in the 123 kit is bigger.
  4. snwcmpr United States
    USA
    NRV pips don't fit. I make SRV pips and they are 5 mm.
  5. Peter.C Australia
    Australia
    G'day guys
    Yes it's a Fettle box pip 4.5mm.
    I guess until you open up the valve you don't know what you have, I'm Lucky to have a lathe. It took me more time to find a 4.5mm drill than machining the holder.
