May 1948 Valor 51 with pressed steel legs
Discussion in 'Valor' started by presscall, Nov 18, 2015.
    No sooner had I posted details of a May 1948-dated silent burner version (the '55') of a Valor with pressed steel legs than the roarer burner '51' came along, also dated May 1948.
    Not mint but barely used and complete with original pan ring, windshield, prickers and two spare jet nipples in a small tin box, colour-matching the Valor windshield. On closer inspection it was not a Valor accessory but once contained 'Flexoplast' brand sticking-plasters. A previous owner with an eye for colour co-ordination as well as function pressed it into use.
    The burner is date-stamped for June 1948.
    No shortage of script on burner or flame ring
    Here's that Flexoplast sticking-plaster box.
    Excellent performer.
  2. Big Si
    Big Si Subscriber
    Mansfield, the heart of Sherwood forest.
    Nice one John, a nice work stove, I gave one away to a bloke on the allotment for him to make his brews with. I normally pass on number five stoves to people as they are cheap easy to fix and work well in sheds and greenhouses, when you need a warm brew or a fry up.
    Si
  3. kaw550red
    kaw550red United Kingdom Subscriber
    Durham NE England
    Hi John
    Is there any signs that it has been a military stove?
    The burner was patented but not by Valor. The patent was originally applied for on August 31, 1943 by Townson & Coxon (Burmos) although the full application was not submitted until January 16, 1945.
    Whilst that type of burner was patented by T & C they made military stoves together with other makers and the War Dept insisted that all roarer military stoves were fitted with the patented burners so other makers made the burners under licence however as far as I know that licence only applied when the other makers were making WD stoves.
    The number stamped on the application is 566,842 which I presume is the patent number which was granted
    I think the marked date may have been a WD requirement. I cannot remember Valor marking the dates on their stoves however my memory is not what it was
  4. presscall
    @Big Si
    Did you find that '96' vapouriser you wanted the jet hole downsizing on?!!! I've got the one you sent me that's sound on my hall stand ready to get back to you. Re. your giving away No. 5 stoves ... doesn't surprise me, you're generosity personified. I've lost count of the stuff you've gifted me at Newarks.
    @kaw550red
    You certainly raise some interesting points there Bryan and thanks for posting them.
    I knew of the patent from Townson and Coxson relating to a removable plug for access to the jet without having to use a universal-jointed jet key but saw that the patent number wasn't that on the Valor and haven't been able to track down the Valor patent.
    No, there's absolutely no 'broad arrow' or other indication of a military origin for the Valor, or for that matter the '55' sister stove with pressed steel legs that I recently posted details of.
    Interesting!
  5. kaw550red
    Durham NE England
    Hi John
    I have looked at other Valor stoves and those showing date marks seem concentrated in the 45-55 period. Those outside that period don't have date codes.
    The numbers on the Valor stove are part numbers (I think) That is apart from the dates.
    Monitor military stoves have the broad arrow on them as well as the date. Until fairly recently unused ex WD Monitor stoves made in November 1955 were still available in so it may be that the 3 legged stoves were dropped for military use about that time
  6. shagratork
    Durham City, England
    This is such an interesting thread!
    There has been mention of not being able to find certain patents.
    I have often looked for patents in vain.
    Why is this? Is there some magic formula?
    I know that Terry (Trojandog) has done a lot of work on this but I am still left floundering.
    As for Big Si he certainly is a generous person and although I see him only occasionally, I count him as a good friend.
    But . . . . . he slipped a bit this year at Newark when I did not get any delicious shitty eggs!
  7. kaw550red
    Durham NE England
    The Monitor roarer military stoves had an unusual burner. The nipple was a standard 0.32 mm nipple but the burner top was larger than the standard 2 pint burners. You got the same heat as a standard burner but you got a much greater flame spread
    http://classiccampstoves.com/attachments/1301753775-flame_rings_opt-jpg.69281/
    The difference in size of flame rings is noticeable.
    If the flame ring on your stove is bigger than normal it is highly probable that it was a UK military stove even if it does not have the broad arrow on the stove
    When I was collecting I copied all stove patents that I found so I could use them to help identify the age of stoves
    The patent for that type of burner was definitely held by the Burmos brand owners
  8. presscall
    @kaw550red
    Hi Bryan
    The Valor flame ring is no larger than a conventional one for an equivalent roarer burner.
    This Primus burner and riser tube is from a Primus 100 stove equipped with a tubular roarer burner, as some were instead of a 'lipstick' roarer burner - I know you know that, Bryan, it's just if someone sees this who doesn't.
    The Valor flame ring fits it perfectly
  9. kaw550red
    Durham NE England
    That's one theory out of the window
