Need Help - Russian 8R clone
Discussion in 'Stove Forum' started by Duran, Jan 8, 2017.
  1. Duran
    Duran United States Subscriber
    Texas
    Hi everyone,
    I just recently received a brand-new Russian 8R clone which I was looking forward to getting started I am not new to this type of stove so I was able to start it without any problems. However, it does not roar, it barely produces some heat output. Any ideas what might be causing this? I am using white gas. I thought being brand-new it needed ample time to warm up especially in cold temperatures like forty degrees.
    Any suggestions on how to fix it? I have used the cleaning needle but no difference.
  2. threedots New Zealand
    Kapiti, New Zealand
    A possibility is that the stove has a slight air leak that does not allow it to pressurise as it should. Check the fuel filler cap for air leaks.
    It could also be something to do with the internal wick. Odd being that it is a new stove though.
    Possibly a poor quality wick or it is too tight in the fuel supply tube. Cheers, John
  3. Robert Bruce
    Robert Bruce Australia Subscriber
    Canberra
    The Russians make quite a robust stove but it can suffer from quality controle, as said check first for air leeks, hot water test is good. Seals could have dried out , wick could be a problem but rule out others first.
    Rob
  4. Doc Mark
    @Aaron Mitchell ,
    From one Texan, to another! Did you over-fill the fuel tank? Sometimes that can cause a weak, or weird flame. You have some good advice as to what to check, in the posts up above. So, give that a squint, and see if you figure it out. Shouldn't be a weak willy, in any case. Good luck, and God Bless!
    P.S. Another thought, if the wick is shoved in too far, or not far enough, that can sometimes cause the problem you describe.
  5. Duran
    Texas
    Thank you for the suggestion guys, much appreciated Doc, I made sure to put just shy of half a tank of gas. What is the best way to check for air leaks please?
  6. Tony Press
    @Aaron Mitchell
    Put pressure in the tank, close the fuel flow, and dunk in water.
  7. Duran
    Texas
    Ok, stove is fixed. Thank you all for all your suggestions.
    It was an air leak on the nut by the gas control. I also put a Viton rubber seal on the fuel cap - figured it wouldn't hurt
    Back in business ...
    One thing though, the stove seems to sit higher or the side hole where the long key goes is lower, I have to use the key at an angle.
    I may have to adjust the side opening unless you guys have a suggestion for this minor thing as well.
    Thank you again!!! I appreciate you all and God Bless!
  8. ArchMc
    Mojave Desert
    A photo of this would be worth 1000 words.
    ....Arch
  9. hikerduane
    Northern Sierra Nevada
    Check for leaks, I've had trouble with the SRV also. I like to put the burner and tank in the freezer for a short time, loosen up the fuel cap first then tighten again before dunking in hot water. This technique allows more time to check for leaks.
    PS--I see it has been fixed. Sounds now like the burner assembly needs to either be screwed in a tad or unscrewed depending on if the spindle needs to be lower or higher.
  10. Robert Bruce
    Canberra
    Asi said quality controle not so good, mine has the same problem with the controle rod, i just live with it. Good stove though.
    Rob
  11. Duran
    Texas
    Thanks, does yours take a long time to prime by any chance?
  12. hikerduane
    They have a smaller priming cup than newer 8Rs. I had to replace the fuel cap washer in my first one twice, the first replacement got hard really fast. Double check for leaks, they are your enemy.
  13. Duran
    Texas
    For whatever reason, mine likes a good warm up. It starts weak even after a good priming with denatured alc. , I let it run in "weak mode" for about a min. I prime it again and when it restarts , it has a beautiful blue strong flame. I love the sound too not too loud.
    I checked for leaks, I don't have any.
  14. Robert Bruce
    Canberra
    Aaron mine primes really quickley , just a bit in the cup and a splash on the bottom. When nearly our open her up then she goes, low flame for a minit then she is a rocket, blue flaim.
    Rob
  15. Duran
    Texas
    would an Optimus 8r Priming cup work on this stove, does it fit?
  16. Duran
    Texas
    Ummm, something may be up with mine then. I get it started very very easily but it never goes into full power no matter how long I let it run unless I re-prime it. No air leaks and I changed the seals too just in case...
  17. Robert Bruce
    Canberra
    image.jpeg image.jpeg Aaron , don't know but can't see why not. Some pice but flaim does not show well on 8r clone. Camping at moment, oh the tranquility.
    Rob
  18. hikerduane
    The threads are different than the real deal. I once tried a Optimus cap that accepts the external pump but would not screw on. They can be picky at times. I use a cut up Tilley butterfly clip for my older 8s for additional meths capacity for priming.
  19. Radler
    Radler Switzerland Subscriber
    Bodensee (Switzerland)
    "would an Optimus 8r Priming cup work on this stove, does it fit?"
    The Russian practise and with the early Optimus R8 instructions too, is to use the fuel to prime:
    Open the filler to equalize pressure and close it again.
    Open valve. Then warm the tank with your hands until fuel flows out of the jet into the priming cup.
    Prime.
    This is a good trick, it guarantees, the wick is wet and the tank equalized. But its sooty.
    Just remember it in a pinch.
    Using alcohol for priming is better, less soot, but needs a larger priming cup.
    Do it like this:
    Take a beer-can.
    Empty it somehow.
    Cut off the bottom of the can carefully.
    Place it under the priming cup.
    Open the filler and close it again to equalize pressure.
    Prime with alcohol.
    Open the valve just before the flame is gone.
    Best Regards
    Radler
  20. ArchMc
    Mojave Desert
