Need Help - Russian 8R clone
Discussion in 'Stove Forum' started by Duran, Jan 8, 2017.
  1. Tony Press
    @Radler
    How do you empty a beer can? ;)
  2. Ray123
    Ray123 United States Subscriber
    New Hampshire, USA
    This is important and necessary on all self pressurizing stoves.
    Aaron, to me the flame shots don't look bad. The flame plate is glowing red, the flame is blue, centered nicely and the stove looks as if it's burning as it should. These small stoves are not really power houses. Both my 8R and Optimus 99 start out a bit anemic and take time to warm up before they run as they should. More than a couple minutes. The cooler the temperatures the longer it takes. I start with a pot of coffee and when that's done 5 or 6 minutes later then it's ready for a skillet.
    Somewhere here on the site an Optimus catalog states the 8R will bring a quart of water to a boil in 6 to 7 minutes and that's probably in a laboratory with no wind and ambient temperatures.
    Ray
  3. Duran
    Duran United States Subscriber
    Texas
    Right on, i like that idea, will definitely try it, thanks!
    Thank you everyone!!!!
  4. itchy United States
    Durham, North Carolina
    I like the beer can bottom trick. But since all beer cans are not equal it is probably necessary to test some different brands and sizes. I'll get started tonight.
    If you don't mind messing up the bottom of the case -- fill the the priming cup with a little more alcohol than it can hold. :content:
    The extra heat helps warm the fuel tank and cuts the warm up time.
    Or you can add a wick, it can hold a lot of alcohol and seems to extend the priming steps.
  5. Duran
    Texas
    Agreed Ray, it is nice at that point but that is after priming it a couple of times. I always open the filler cap first to equalize pressure as well as rotate the knob fully to the left and close it back. Again, i can live with priming it twice or will try a bigger cup for prming.
  6. gieorgijewski Poland
    You mean - 40 or + 40
    if -40 - You need extra heat transport to tank for normal works
  7. Duran
    Texas
    I like your setup Rob - pretty seet. What are you using for windshield on the Russian stove please?
  8. Duran
    Texas
    No, I mean +40 It got in the 30-35 here last week.
  9. gieorgijewski Poland
  10. Duran
    Texas
    The can bottom trick worked awesome, and it stays there like it was meant for the stove. Thank you again for the suggestion.
    Also, whoever said beggars can't be choosers, they were wrong.
    I have to ask another question to all.
    I have a Korean Shinabro 8r clone. Works great but the fire shoots out more on one sure than the other. I know it is not the fire spreader and the injector and the whole arm seems pretty straight up.
    And no, not the wind either:-)
    Any ideas what it may be?
    Not a show stopper but sort of a mild case of OCD.
    Here is a pic of it next to my Russian Primus stove.
  11. Tony Press
    @Aaron Mitchell
    If everything is straight, it could be the jet (the hole in the nipple).
    If you have a very fine cone or ball shaped grinding tool, gently round the very top of the jet (only a few thou.). Then make sure the jet is clear, and see if that helps.
  12. Robert Bruce
    Robert Bruce Australia Subscriber
    Canberra
    Aaron, my set up on the Russian 8r is a wind shield and shield for the tank made from copper. It tarnishes quick but for a user that's ok. Also it was at hand so I used it.
    Rob
