Removed the jet from my 111 and found the cleaner wire had bent? Gave it a warm and tried to straighten but it snapped Base camp do have spares but has anyone out on the park ever had a go at replacing the wire pricker
I tried this several times. Where the problem comes from is the wire pricker is harder than the brass . So when you try to drill a hole with these small drills , the drill will break also you run off centre. Good luck. I think a drill this size will cost as much as a new pricker or close to it.
If there's a broken piece of pricker in the jet, it can be removed by de-greasing it with petrol, and leaving it in vinegar. I used to repair watches, and if a screw broke in a plate, it could be removed with the above method. It may take a week or two, though! Jim Ford
