Optimus 9 stress-cracked tank repair - the story so far
Discussion in 'Fettlers Master Class' started by presscall, Jun 25, 2016.
  1. shagratork
    Durham City, England
  2. Normo
    Normo Australia Subscriber
    Melbourne, Australia
    I ...am ...impressed.
    I look forward to future progress.
  3. Funfundfunfzig
    Funfundfunfzig Australia Subscriber
    Melbourne
    Roger that @Rickybob! Yes! I always get them confused! Apollo 11 was the one with Neil Armstrong, Buzz Lightyear and Phil Collins...I was thinking of the one with Tom Hanks, Bill Paxton and Kevin Bacon! Wilson!!!
  4. Metropolitantrout
    Metropolitantrout United States Subscriber
    Looking good John and thanks for accommodating my request! :thumbup:
    You make it look easy. :clap: Jerry
  5. Big Si
    Big Si Subscriber
    Mansfield, the heart of Sherwood forest.
    Nice work John, expected nothing less though!
    Si
  6. Doug L
    New York
    John your amazing. You should have your own television show on the BBC (Fettle Network). Wish I had half your talent.
  7. presscall
    @Doug L
    Well, the repair is pressure proof. I fitted the burner from an Optimus 111B to enable the tank to be pressurised and dunked in a bucket of water.
    I ended up putting two more countersunk screws in-between the centre and end fixings. I ground down the excess of the set screw heads and cut a groove along the line of the crack and into the brass splint beneath to provide a key for the solder.
    Alas, a skim of solder to produce a flush just didn't seal the repair and I'd no option but to leave a bead of solder proud of the surface.
    So, job done insofar as the stove will be functional and the repair is underneath the tank so won't be visible when the stove is in use. A strong repair too, but I could have wished for a neater outcome. I suppose it adds to the 'provenance' of the stove if you file this documented repair process with it!
    Let me have your thoughts Doug.
  8. teckguy_58
    Spokane, WA
    @presscall
    Hi John,
    That is one fine repair job. Well done, John and bravo on your ingenuity with this repair.:clap::thumbup::thumbup::thumbup::thumbup:
    Norman
  9. Doug L
    New York
    John great work! I can't thank you enough.
    I am anxious to fit it up with the burner and try it out.
  10. ArchMc
    Mojave Desert
    Superb repair, and you needn't feel bad about the bead of solder. The repair is a proud part of the provenance of the stove, regardless.
    ....Arch
  11. snwcmpr United States
    USA
    A master fettler.
  12. Doug L
    New York
    I agree guy's.
    John should be knighted for this as Sir John Master fettler
  13. Doug L
    New York
    Ok I just got off the phone with the Queen.
    Here is how it will go down.
  14. shueilung.2008 Uruguay
    Uruguay
  15. Rickybob United Kingdom
    Bravo Maestro!
    you have excelled yourself!
    you have the vision, the smarts and the technical chops to get this done so your reputation is now cast in stone
    you might rest a while upon your laurence, but more challenges await you
    challenges to test your remarkable skills!
    you will astound us all again, i know it
    and i happen to think that it is a very tidy solder fillet and much more satisfactory than any 'invisible repair' could ever be
    a testament to your efforts!
  16. shagratork
    Stunning work by a Master Fettler :clap::clap::clap:
  17. Spiritburner
    Amazing job. I shudder to think of the mess that stove would be in if I tried to do that!
  18. Funfundfunfzig
    Melbourne
    Sir John the Stove Sur-geon!
  19. presscall
    Thanks all!
    It took longer to complete than I could have wished but the rarity and value of the stove prompted me to proceed with caution and to work on it only when I'd no distractions or was not chilling out after a day's work.
    Posting progress 'live' and not retrospectively with the job already done was a decision I'm glad I chose. It provided the incentive to get it done - eventually! - and I valued your comments and suggestions along the way.
    Speaking of those suggestions, that to 'remove the end caps' and replace the cracked tank with a new cylinder subsequently to nickel plate made me ponder but rule out. There's just one end cap and the tank is a deep-drawn fabrication with a domed end and waisted shape at the pump end. Reproducing that distinctive tank would have required one-off tooling and would have entailed prohibitive expense.
  20. Billyboy
    Billyboy Canada Subscriber
    Leduc, Alberta, Canada
    Well done, John. Unreal.
    Now a flame shot?
