Optimus Mini Oven
Discussion in 'Stove Paraffinalia' started by Giri, May 17, 2016.
  1. Giri
    Giri Canada Subscriber
    Canada
    Came in the mail today.
    Hope to add some actual baking shots in the near future.
    Seems to rest well atop a Sigg stove holder or a Trangia 27
  2. kerophile
  3. Giri
    Canada
    Thank you Kerophile,
    The Omnia cook book is great - I even see that they lifted some of the recipes directly from the Optimus insert.
  4. fire bug
    fire bug United States Subscriber
    Does anyone have a PDF version of this book?
    Zimmerman, Sybil, illustrations by Marion Alderman The Wonders of a Wonder Pot, or cooking in Israel without an oven (1973) Jerusalem: Jerusalem Post Press. She had also written another book: Israeli Cooking on a Budget.
    I have been curious about both of these but obviously not enough to purchase them at collector prices, so if anyone knows if there are electronic versions out there a pointer in the right direction would be greatly appreciated!
    Thanks,
    FB
  5. kerophile
  6. ke6ziu United States
    I recently baked biscuits on my Trangia clone... they came out pretty good, albeit a little dark on the bottom! Need to use the simmer ring with it!
  7. kerophile
    Hi, there is a shaped base piece on Wonder Pots, which has a dual function:
    It acts as a bottom-shield to prevent scorching of the contents, while helping to direct the heat up the central funnel of the oven.
    Have a look at some of these old threads:
    http://classiccampstoves.com/threads/optimus-mini-oven-poor-mans-version.8244/#post-81566
    http://classiccampstoves.com/threads/mini-oven-and-irish-oatmeal-soda-bread.8292/#post-82186
    http://classiccampstoves.com/threads/hipolito-no-1.10052/#post-97486
    http://classiccampstoves.com/threads/wonderpot-stove-top-oven.21386/#post-219750
  8. Giri
    Canada
    I am pleased to report that the author has reprinted the book - The Wonders of a Wonder Pot
    This blog post from April 17, 2015, written by the author (now last name Kaplan) has her e-mail address listed to contact her.
    I just e-mailed her to inquire if she has any copies left of the reprint.
    Cost is $25 including shipping.
    The other book Israeli Cooking on a Budget is available used on Amazon.com starting at $2.05 plus $3.99 shipping in the USA.
    Unfortunately $20 shipping to Canada.
  9. kerophile
  10. OMC
    OMC United States Subscriber
    Illinois, the Land of lincoln
    Giri, Kerophile,
    Recapping what Giri mentioned far above referring to two ovens, his Optimus mini-oven and the Omnia (they do look very similar at a glance).
    They may be about the same size, Omnia although smaller than my other ovens is not referred to as "mini".
    I note his Optimus lid's recessed handle, makes the top flat across. Omnia lid the handle is up, the top is not flat.
    I now have a banged up Omnia here, I can see the pans differ slightly too.
    Absent side by side image comparisons, dims may be helpful, my Omnia:
    the pan OD: 227 mm, height 63 mm
    volume is 1.5L exactly (measured liquid, full to brim).
    thx omc
    tag @kerophile @Giri
    Omnia sample image, found retail $57 on sale:
  11. OMC
    Update, I noted above two differences: lid and pan.
    In particular note the center of Giri's pan.
    Well as it turns out it is not accurate for me to describe different pan as a difference between Omnia and Optimus. I now see Optimus used different pans along the way (and left to wonder how differences may effect performance).
    Note Bibbt's Optimus pan also differs from Giri's. I see other Optimus examples as well, 1 image below. That said, I've no doubt Giri's is excellent NIB type example as shown.
    -and-
    I also have now translated an OMNIA ad describing it as
    ...like the classic Optimus [mini-oven] now reintroduced...
    In hindsight, my comments above would differ. IE less interest in comparing pans as Optimus at some point used pan that looks exactly like an Omnia/mine.
    Credit Kerophile observation, revert to his impression as it stands "...Omnia and Optimus may be the same Group"
    The image above is of another NIB Optimus example but w/pan just like the Omnia.
