Parasene 1/2 Pint 'Safety Stove' with Zora burner
Discussion in 'Parasene' started by Admin, Nov 14, 2012.
  1. Admin
    Admin Courtesy of Iani
    Here is another variation of the Parasene/Zora burner/stove.
    A bit surprised to see how thin the brass on the base is.
    In the last picture is another incomplete variation. The filler cap/pressure release valve is different.
    1352910159-IMG_8801_opt.jpg 1352910201-IMG_8806_opt.jpg 1352910232-IMG_8816_opt.jpg 1352910267-IMG_8802_opt.jpg 1352910296-IMG_8803_opt.jpg 1352910314-IMG_8804_opt.jpg 1352910335-IMG_8805_opt.jpg 1352910363-IMG_8807_opt.jpg 1352910563-IMG_8856_opt.jpg 1352910610-IMG_8810_opt.jpg 1352910641-IMG_8821_opt.jpg 1352910669-IMG_8815_opt.jpg 1352910701-IMG_8819_opt.jpg 1352910752-IMG_8820_opt.jpg 1352910792-IMG_8799_opt.jpg 1352910825-IMG_8800_opt.jpg 1352910858-IMG_8824_opt.jpg 1352911148-IMG_8861_opt.jpg
  2. Bom Bom Bom Bom
    Hey Ian,
    Are you playing catch up with posting a whole bunch of stoves you already own, or are you acquiring and fettling one a day? A stove a day keeps the doctor away?
    Thanks for sharing all these though. I should do the same, but despite trying to defy the laws of relativity I've failed miserably to manufacture time.
    Cheers, Graham
  3. Admin
    No fettling on this one Graham, it is as received.
    Probably virgin at that.
  4. Bom Bom Bom Bom
    Very nice. Interesting that the spanner is quite similar to the Radius spanners rather than just being a plain cut out.
    Cheers, Graham
  5. Admin
    What I find interesting about this spanner, is the word Rowen. Rowen pressed lettering on tank Note the outer burner cap, Parasene had an influence in these stoves, I believe, and also see Rowen with decal. This burner plate is more eliptical, similar to the Zora plate, although a bit bigger.
