Primus 1117 Oven
Discussion in 'Stove Paraffinalia' started by z1ulike, Nov 6, 2016.
  1. z1ulike
    z1ulike United States Subscriber
    Primus 1117 Oven front view
    Bottom view
    It came with a Primus 582 heat shield, cookie sheet, baking pan, and an asbestos protector.
    I can't make out the English printed on the asbestos protector. The Swedish is clearer and hopefully someone will translate.
    I doubt the cookie sheet and pan are original but they are very well made out of heavy gauge and fit the oven perfectly.
    I decided to try it out by making some scones so I first preheated the oven to 425 F (218 C).
    I decided to use my 1932 Primus 14 because it has a burner that can be easily regulated and it is in perfect running order thanks to Gary (Bernie Dawg) Adams who fettled it for me.
    I made the scones and placed them on parchment paper for baking.
    I used an electronic thermometer to monitor the oven and popped the scones in when it got up to temp which took less than 5 minutes.
    The scones baked for the required 12 minutes and came out great especially after I added a little butter and homemade fig jam.
    One parting shot of the Primus 1117 oven and the Primus 14 stove with the Primus 582 Heat Sheild.
  2. MrAlexxx
    MrAlexxx Canada Subscriber
    Canada
    I like that. :thumbup:
  3. Doc Mark
    Hey, Ben,
    Lovely!! Thanks for sharing this neat old oven, and congrats on scoring it! Take care, and God Bless!
  4. scouterjan
    scouterjan Canada Subscriber
    Maple Ridge, B.C. Canada
    learned something new today, I have never heard of 1 before
    Jan
  5. kerophile
  6. Christer Carlsson
    Christer Carlsson Sweden Moderator
    West coast of Sweden
    Ben, it still says:
    Use this plate only when reduced bottom-heat is required
    Have you already forgotten that you asked the same question not that long ago? ;) :lol:
    Check this out.
  7. Tracer
    Tracer Belgium Subscriber
    Great stove!
    Perfect way to prepare scones, I guess the 1117 oven heats faster up then an electrical oven.
    Congratulations with such a nice sco(r/n)e
  8. z1ulike
    Like my grandmother used to tell me, "you'd forget your head if it wasn't attached to your neck!"
    I was also trying to remember which Swedish member of CCS helped me obtain the oven. I narrowed down to @Lighthouse or you but I wasn't sure. Thanks for refreshing my memory on both accounts and thanks again for your invaluable help in obtaining the oven.
  9. pau-i-amor
    pau-i-amor Spain Subscriber
    My mother use to told me the same words!!! :lol: :lol: :lol:
    What a nice stove, Ben!
  10. Longilily
    Longilily United Kingdom Subscriber
    Dungeness
    Loving the oven Ben :thumbup:
  11. Rangie
    Rangie Subscriber
    Caithness, Far North of Scotland.
    Lovely, lovely!
    I have been on the look-out for one for some time with no luck :(
    Is it a double-skinned device or does the waste heat escape through the door buttons?
    Alec.
  12. z1ulike
    The answer to your question is both :-k. It is a double skinned oven but the door is a single sheet with two holes where heat might escape. There are also a series of holes on top of the stove for heat to escape. I believe heat from the burner enters through the bottom of the oven, goes around the oven between the inner and outer skin, and exits through the holes in the top. That way the food inside isn't exposed to stove fumes and the scones don't come out smelling of kerosene. I'll know for sure when I get around to tearing it apart to re-paint it.
  13. NW Lady
    NW Lady United States Subscriber
    Washington State
    I love that oven. Haven't seen one like that! Primus 117 oven...added to my "really want" list! Roughly, what are the dimensions? thank you
  14. z1ulike
    The oven is 7 1/4" H x 14 1/2" L x 10 1/2" W and the legs are 9" making it 16 1/4" high overall. The pans are 9" x 13" and the interior is 4 3/4" tall.
  15. NW Lady
    Washington State
    Thank you. Big enough to get a good sized baking pan in and with the legs fits right over a stove...very nice. I did an internet search... very scarce... but I can hope. Congrats on that find!
  16. kerry460
    kerry460 Australia Subscriber
    Tasmania , Australia
    G,,day mate , i like it .
    i look forward to then pizzas from it .
    kerry
  17. Robert Bruce
    Robert Bruce Australia Subscriber
    Canberra
    Ben, very nice oven. I see you mention the heat shield, is it only nessery on your type of oven ? Why I ask is I have just got a Coleman oven , new, and are going to use it with a Primus. Should I make or get a heat shield for it or not ? The oven is single skinned and looses a lot of heat, some cover it with foil but for occasional use I don't think it is nessesary.
    Rob
  18. z1ulike
    @Robert Bruce I don't have an answer for you. Catalogs in the Reference Library show the oven being used both with and without the shield.
    Here's an explanation of the plate (shield) from a 1937 catalog.
  19. ArchMc
    Mojave Desert
    When using a Coleman oven with a Coleman two-burner stove, the fuel tank is not directly under the oven. Personally, I would use a heat shield of some sort for any stove that has a fuel tank directly under the burner. (I'm assuming it will get too hot for your hand under there, which is probably a pretty good rule-of-thumb.)
    ....Arch
  20. Robert Bruce
    Canberra
    Thanks Ben and Arch, looks like I will have to make one, looks an relitively easy job. I will see also how hot it gets under the oven . I made a stand that collapse down as the oven was a bit unstable with a Primus single burner under it. The oven is a bit flimsy but I suppose weight was an issue.
    Rob
