Nice stove indeed!! One of my favorite stove the Primus 96 and 97. I like the patina look. Cheers, Jeff
Indeed, lovely stove! Just a "soft" clean would be perfect, if you plan to use it. Can we see it "at work"? Regards, Wim
Sure I will fire it up if I can figure out what I need to replace on it, it hasnt been used in over 20 years. What would you call a soft clean Wim? I like the sound of that rather than a hard polish.
Just a wet rag&soap approach, if the clear varnish is still on the stove, to take away the dirt. You could even try it on the box and such, I like to see these stoves have had a life! Regards, Wim
Outstanding stove. Good Show. Now, you are cool, too! No, really, very good move. I love them. Al in Oklahoma
Hi Steve, the Pr.96 has a half-pint tank, whereas the Pr.97 is fitted with a 1-pint tank. I believe that they share the same burner size. Best Regards, Kerophile.
Can you still buy a lipstick jet for these, would be good to keep a spare. It wasnt too hard to get up and going just new filler cap seal.
I also have 2 of these stoves. The interesting thing is that they both have the same date code on the bottom as your one S28, now i thought 2 was a coincidence but 3 in NZ maybe part of the same shipment
