I got one of these off fleaBay, less burner plate, valve key and carrying case. The burner plate turns out to be same as a 8R/99, and I had a spare, so that was no prob, a new O-ring for a seal on the bottom fill, fired 'er up, and it's all good. There are two grooves lathe turned in the top of the jet, where the flats are--is this an indicator of a special application jet? Other question, where can I get a valve key/jet wrench for this little pup? Murph
Hi there, any idea what year this model would be from? I've recently found and started cleaning up one that looks identical to this only much worse condition! Thanks
