'Sickly' Borde made well
Discussion in 'Fettlers Master Class' started by presscall, Aug 22, 2016.
    @Doug L
    In THIS post relating to an Optimus 9 cracked tank repair I wrote,
    Doug told me he had already worked on the Borde, drilling out the tip of regulating spindle that had jammed and broken off in the jet orifice. Here's how the tip of the component should look (photos courtesy of Hazet from his Stove Reference Gallery example).
    Here's the component on the Borde requiring repair.
    The absence of that tip isn't what prevents the stove from working properly. It's the fact that the jet hole is now oversized and whereas this should happen (patent drawing) ...
    ... there was no positive shut-off, the regulator spindle entirely disappearing into the jet orifice and not stopped at the tip of the jet.
    I first explored the use of short lengths of hypodermic needles to repair overly large lipstick burner jets HERE - an idea suggested by Doug appropriately enough.
    Consulting THIS chart of hypodermic needle gauges I saw that a 16-gauge needle has an outer diameter of 1.651mm and a bore of 1.194mm. That's just the right outer diameter to line the jet hole but smaller than the diameter of the regulator spindle.
    Here it is silbrazed in place.
    Excess needle trimmed off, jet seat squared off, regulator component in place.
    Fuelled up and fired up. Controllable and it can now be shut down!
    Mmm ... Should I?
  2. Billyboy
    Billyboy Canada Subscriber
    Leduc, Alberta, Canada
    Yes! Of course you should! :mrgreen:
  3. presscall
    Night fell.
  4. kerophile
    Hi John, Master of the Hypodermic, Tamer of the Borde, etc.
    Masterful resurrection of a desk paper-weight back to a fully-functioning blowlamp/stove.
    What a great post, and with a happy ending. I hope we can see some more flame shots once it gets dark.
    George.
  5. Metropolitantrout
    Metropolitantrout United States Subscriber
    Smart and well crafted fix - very impressive! :clap::clap::clap:
    -Jerry
  6. shagratork
    Durham City, England
    Neat, masterful, gobsmacking!
  7. Giri
    Giri Canada Subscriber
    Canada
    Wow
  8. Big Si
    Big Si Subscriber
    Mansfield, the heart of Sherwood forest.
    Nice fix John, as ever.
    Si
  9. snwcmpr United States
    USA
    Wow x 2!!
  10. hikerduane
    Northern Sierra Nevada
    Nice job, mine burns a little yellow. :(
  11. SGL70
    SGL70 Sweden Subscriber
    Luleå, Sweden
    Wow!!
  12. Doug L
    New York
    Sorry I'm late on this post.Glad to see you were able to get it up and running John and with the hypodermic fix.I should have guessed.
  13. Tony Press
    :thumbup:!
    Nice work, John.
  14. presscall
    Update
    I decided to return the regulator/burner plate to specification by restoring the broken-off tip. I took a short length of stainless steel wire (1.5mm diameter) and silbrazed it to the tip then machined it to a (roughly) triangular section with a hand-held Dremel and a diamond abrasive wheel.
    Makes no difference to the function - probably would if burning pump petrol and it had to ream the jet as mentioned in the patent to remove combustion coke - but it completes the restoration.
  15. snwcmpr United States
    USA
    I was re-reading this great thread and was about to ask that question. Now answered.
    A great job, John.
    Ken in NC
  16. shueilung.2008 Uruguay
    Uruguay
  17. presscall
    @snwcmpr
    I've been using the Borde rather a lot - great stove, I can understand why it has an entusiastic following - and have been giving more thought to that 'reamer' tip.
    Going back to the patent I reproduced the illustration from that reamer function is clearly stated, to scrape away any coke deposits left by burnt fuel.
    Depending on the quality of the fuel (I'll be using Aspen exclusively) that reaming function could make the difference between the stove working or not. Without the reamer tip the jet outlet could block altogether preventing the release of a priming charge of fuel from the tank.
  18. snwcmpr United States
    USA
    This does seem like such a simply well made, no frills, stove. Uncomplicated solutions. The reamer, not just a pricker, but a cleaner. Wow.
    I cannot fathom that someone doesn't pick up the baton and start making them again.
    @presscall that IS along the lines of the question I didn't ask.
  19. Murph
    Because the cost of liability insurance would rip you a new one, big time!
    Murph
  20. snwcmpr United States
    USA
    Yeah, with the misgiven nickname "Bomb" someone would easily gain from their own mistake.
