Sunflower No. 2
Discussion in 'Vacuum Oil Company' started by z1ulike, Sep 20, 2015.
  1. z1ulike
    z1ulike United States Subscriber
    This is a "Sunflower" Vacuum Oil Company, No 2. It was made in Portugal by Cormache.
    It seems to be very well made of heavy brass and runs like a champ. Other than that I don't know anything about it. I can't find anything on the Cormache company. It seems similar in design to some of the Hippolito stoves also from Portugal but I don't know if there is really any connection. Hopefully the sizable knowledge base here at CCS can shed some light or at least some speculation.
  2. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    At first glance, I thought it was a Hipolito No. 2 with those distinguishing feet. At any rate, it's a fine looking stove and if it was made by Hipolito, it's probably well made.
    sam
  3. abman47
    abman47 United States Subscriber
    Ben Lomond
    Hi Ben, what does the bottom of the stove look like; is it smooth, or is there a ridge/step an inch in from the outer rim? I have a stove made by Cormach of Portugal that has the same feet and profile as your stove. The fount is obviously stamped differently, not being a Sunflower; mine is also lacking the "E" at the end of Cormache, and any bottom stamping.
  4. z1ulike
    abman47,
    The bottom of the stove is just as you described it:
    By the way, are you an abalone diver? I was just up diving at Elk in Mendocino County and came home with 9 inchers. Yummm.
