Tilley CS56
Discussion in 'Tilley' started by presscall, May 5, 2011.
    With a birthday imminent, I was asked by my immediate family whether I'd prefer "a surprise gift or something you'd really like to choose for yourself?"
    No contest, I chose this
    The burner parts
    Fuel cock and fuel cock to tank adaptor ring
    Pump and non-return valve components
    Tank, enamelled windshield and pot rest 'superstructure'
    The burner in process of assembly
    Here's the burner cap with the gauze lining to prevent flash-back/underburning
    A comparison shot here between the Tilley stove vapouriser/generator and internal pricker wire (about three-and-a-half inches long - 9 centimetres) and a Tilley vapouriser and wire from a PL53 lantern, the lantern vapouriser and wire being about twice the length of the stove's.
    With replacement vapourisers for the Tilley stove being virtually unobtainable, I've a plan in mind to cut down a readily available lantern vapouriser and pricker wire to size, silbrazing the adapted components together. There's one significant issue however, and that's the greater jet orifice diameter of the stove's vapouriser, evident from these photos
    Food for thought about constructing a spare vapouriser tube - oh, and a Vapalux-type priming cup to construct too - but meanwhile I'll reassemble the stove and post some photos of it fired up, shortly.
  2. Big BTU
    Big BTU United States Subscriber
    Hawaii
    John your detailed breakdowns and great pictures are always appreciated! Wonderful looking stove too, can't wait to see it fired back up.
  3. mr optimus
    Hi John, first of all happy birthday when it comes and what a great choice of a stove and not too common, in fact quite hard to come by.
    On another note, brilliant documented thread and write up. These stoves I must say are really interesting and have some great features like the burner cap gauze lining to prevent under-burning. The only snag with the Tilley stove is it has a seperate flame system to keep the vapouriser hot enough to vapourise the fuel so a little extra fuel is used on this process. But still more economical to use than a gas cartridge stove and when lit it gives a more interesting flame pattern. I am looking forward to seeing this fully fettled to your very high standard and running.
  4. RonPH
    John! What a nice birthday present (to yourself). I look forward to seeing it fired up. I see you have been busy down at the workshop again.
    Ron
  5. Doc Mark
    Happy Birthday, John!!
    :clap: :clap: :clap: :clap:
    What a wonderful family, to think of asking about your birthday present preferences!! A blessing, indeed, and well done!
    Very nice pictorial on your new stove, too, John! Like the other Lads, I, too, look forward to seeing it working as it should, back in its glory, celebrating your birthday in Stovie Style!! ;) 8) :thumbup: :D :D
    Again, have a very happy birthday, my Friend, and here's to many more to come! Thanks for sharing your special day, and special present, with us. Take care, and God Bless!
  6. Wim
    Wim Belgium Subscriber
    Hi John, congrats with your birthday, and another congrats on your lovely birthday present! :D/ :clap: :D/ . You certainly have a good taste... O:) .
    Enjoy your weekend,
    Wim
  7. presscall
    Many thanks for the best wishes all ...
    Well, it's not my birthday just yet, but I'm having a lot of fun with this Tilley already.
    I decided to have a go tonight at making a 'short' stove generator out of this candidate, a well-worn vapouriser from a PL53 lantern
    Yes, a ropey old thing ...
    ... but with a brass screw fitting, which I prefer to the economy steel version in later production runs of Tilley vapourisers
    I cut the tip off first, then a section of the middle section so that silbrazing the tip to the screw-mount part gave me a vapouriser of the right length
    This funnel arrangement was in the tip, which is a guide for the pricker wire, so I'll keep it there
    Job done
    I said in my original post that the stove vapouriser has a larger jet orifice than the lantern version, so I prepared and silbrazed in a brass insert with the correct size of hole (0.23mm) using the techniques I developed and reported on in the fettling forum, here:
    Easy 'drilling' of 0.23mm holes and repairing a Monitor lipstick burner
    Here's the result
    I've a pricker wire to construct yet from a cut-down lantern one, but I'm getting nearer to that test firing!
  8. gunsoo
    gunsoo Korea, Republic of Subscriber
    Hi John.
    Thanks your detail picture about CS56 stove. Wow I think your short vaporiser nice made. :thumbup:
    gunsoo
  9. Ian
    Ian United Kingdom Subscriber
    West Riding of Yorkshire
    Nice work, John.
  10. presscall
    Trying the original short vapouriser pricker wire in the vapouriser tube I'd constructed, I found that it wouldn't engage with the jet orifice.
    The problem was a slight off-centredness to the jet I'd inadvertently imparted when brazing the insert and I'd not made a smooth enough 'lead-in' taper to the hole on the reverse side to guide the tip of the pricker wire into position.
    So I'd to make a better job of it
    Brazing cleaned up, vapouriser in position
    Checking the pricker functions properly ...
    ... it did.
    Stove reassembled, ready for a fill of paraffin, using the distinctive Tilley funnel and with the Tilley priming jar and Tilley pre-heater torch to hand. The original vapouriser is now a useful spare.
    Flame shot
    On full power there's a tendency for the flames to lift away from the burner cap, but I've a feeling that's a characteristic of the stove rather than an issue with the vapouriser
    It certainly puts out the heat, which is pretty good going for a stove with a jet orifice the same (0.23mm) as that of a Primus 96's.
  11. mr optimus
    Hi John congratulations on a remarkable fettle through out and it realy does put out the heat considering it has only a 0.23mm jet orifice. And all the pics of these stoves running at full power has the same flame lifting away from the burner so a perfect job you have done, John :clap: :clap: :clap:
  12. presscall
    Thanks Brian.
    Some detailing next.
    Though it's my first Tilley stove, I've handled quite a few Tilley Lamps and still keep a few. Something I find perks up the overall appearance is to re-line the white paint in the engraved "Tilley Lamp" in the plastic control knob.
    On the stove's control knob what remained of the faded white paint lifted when it was in the ultrasonic cleaning bath with the other parts
    To re-line the paint I use a white paint marker pen intended for metal layout work
    At first the result's a mess, but a quick wipe with a solvent-dampened rag while the paint's still wet gives the intended effect
    Later tonight when it's dark I'll round of this topic with some flame shots, including those remarkable 'flamelets' on the three vertical tubes below the burner that play on the vapouriser tube.
    Meanwhile, a couple of shots in the half-light
  13. presscall
    Tilley put what they call the 'burner outer gauze' (that stuff glowing red in those flame shots) there for a reason. Their instructions for the Tilley stove recommend that the stove is working at optimum pressure when the tank pressure indicator ... that's this thing here ...
    ... shows the centre level with the outer rim.
    Without the burner outer gauze and the tank pressure at the level recommended by Tilley, the flames lift off the burner and are extinguished.
    There's no doubt that without the gauze, the burner head shows a purer blue, but the tank pressure has to be reduced to make that possible
    I'd be quite happy to use the stove without the gauze, but the tank wouldn't be putting out maximum power (when that matters for specific cooking tasks) and I can understand that Tilley wouldn't want to market a stove with the potential to self-extinguish if the user pressurised the tank above a certain level.
  14. teletim United Kingdom
    Happy Birthday. Fantastic Fettle.
  15. Ian
  16. presscall
    Indeed, Ian.
    It was your CCS shots of the burner in action without the windshield and seeing your stove burning contentedly at Newark last year that made me hanker after one.
    Took a birthday (and a sixtieth one at that) to justify the expense though!
  17. presscall
    Thanks Tim.
  18. johnabutterworth
    Hello All,
    I just wanted to say thank you to all of you who have posted information regarding the CS56 on this page. All this information greatly helped me in getting this CS56 back to working health. After some consultation with the folks at Fettle Box I had the proper replacement gaskets and was in business.
    I do have one significant question regarding this stove. In the pic you'll see that the stove is lit and working just fine. What I'd like to know is if I was dangerously close to killing myself.
    I did not have any kero at hand, but did have some White Gas or Coleman Fuel. The stove lit easily and burned well, but I have read elsewhere that it is very unsafe to use this fuel in Tilley pressure lamps. Is the same true of the stove?
    Again thank you for putting this information out there. I'm delighted to have a new stove to tinker with, but just don't want to blow myself up in the process.
    Take Care,
  19. presscall
    Glad the details were useful to you John
    Close to killing yourself? Probably not, but the stove is meant for paraffin and hasn't got the safety features that make Coleman stoves safe for burning Coleman fuel or white gas.
    You did right to change all the gaskets and that's ensured that your foray into using white gas was uneventful. If you hadn't it could have become a fireball and even if you got off unscathed your lovely Tilley would have suffered, cosmetically certainly but also probably de-soldering of the pump base joint and damage to the pressure indicator pip device (not user serviceable, so a replacement font would be needed).
    Not worth the trouble to use anything but kerosene as fuel, de-natured spirits as priming fluid.
  20. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    Hi John,
    Thank you very much for a very nice post. I missed this one when it was first posted.
    I do have to say that the Tilley burner is a beautifully complicated little beast that I wish was more common a little more westward across the little puddle that sits between us!
    Thanks for sharing and the great work up!
    sam
