Townson and Coxson twin burner (petrol) 1953
Discussion in 'Military' started by presscall, Jul 27, 2013.
    I've been on the look-out for one of these for a while.
    A fettler's dream and a manufacturing and sales nightmare I expect for Townson and Coxson.
    A real money pit for T&C, who seem to have gone for the most complicated, the most expensive engineering for something they must have stood no chance of selling in volume to the military and even less in civvy street.
    It still can't sell well and I picked it up cheaply.
    A fettler's dream indeed. The containing box and pot rest frame are out of shot awaiting restoration, but the components here are pretty much done - one burner and control valve detached for stripdown
    Sam won't mind that I borrowed his photo to illustrate how the stove looks complete
    Sam's T&C in Stove Ref Gallery
    The inventory of materials and construction is impressive ... twin brass fuel tanks, linked by tubing so that both tanks are scavenged of fuel, star-shaped (easy grip) aluminium fuel filler cap; bronze control valve spindles; composite control valves comprising brass bodies and steel lipstick burner tubes; locking (closed) pump knob; auto pricking jets on regulated burners; stainless steel disc jets
    A burner and control valve
    When the burner basket is screwed down onto it that stainless steel disc provides the jet orifice
    In switching off the burner the control valve spindle drives a pricker wire through the jet orifice
    To assemble the valve, the spindle has to be screwed into the valve without the pricker nut screwed in place.
    This hexagon socket tool clamped on the stove frame is used to screw the pricker nut on the control valve spindle ...
    That socket tool contains a couple of spare pricker nuts and jet discs
    MORE TO FOLLOW AS THE RESTORATION CONTINUES
  2. DAVE GIBSON United States
    Minneapolis Minnestota USA
    How did the disc jet work in practice? They look like the best idea in all that complex machine work.
  3. Admin
    Admin Courtesy of Iani
    Why on earth borrow Sams, when yours is complete ?
  4. Spiritburner
    I've certainly stripped down a stove before & forgot to take a 'before' picture. No big deal?
  5. presscall
    Exactly, Ross, you correctly sussed "Why on earth ...?"
    Good grief, Ian.
    Ok, more work on it completed.
    This reamer device comes with the stove
    A plaque on the stove box suggests using it to decoke the burner vapouriser tubes
    The vapouriser tubes were pretty clean, but any carbon would hinder the free movement of the regulator controls, the action of which is to rotate and move up and down in the bore that triangular spacer spacer, which is actually intended as a steadying device to ensure the pricker needle is centred to penetrate the jet orifice in the jet plate.
    Orthodox pricker needles have conical tips to match the interior contours of jets to ensure the needle and jet orifice engage
    Replacing the control spindle packing. The existing stuff was some fibrous material (asbestos in there certainly). Though I wasn't queasy about the asbestos as such it wasn't such efficient packing, porous to petrol judging by the smell of it
    Terry (Trojandog) markets some great packing material. Thin sheet, a strip of which is cut to width and wrapped round the spindle. When the packing nut is screwed down it crushes into place and makes a perfect seal
    Pump seals replaced. Non-return valve is Tilley pattern
    Goes well, heat shield in place as a precaution
    Dave Gibson asked,
    Works well Dave. No less control or a worse flame pattern than with a conventional jet. Pretty good.
  6. presscall
    I spruced up the stove case a bit as the final job and reunited the fuel tank and burners unit with it, setting a proper squaddie-sized kettle to boil on it and swapping one of the roarer burner plates with an old favourite - a BernieDawg TD cap intended originally to convert a British Army No.12 to silent burning mode
    1375138669-1.JPG 1375138676-2.JPG 1375138830-4.JPG 1375138705-3.JPG 1375138841-5.JPG 1375138854-6.JPG 1375138873-7.JPG 1375138887-8.JPG 1375138899-9.JPG 1375138910-10.JPG 1375138927-11.JPG 1375138948-12.JPG 1375138964-13.JPG 1375138981-14.JPG 1375138995-15.JPG 1375139013-16.JPG 1375139036-17.JPG 1375139054-18.JPG 1375139174-19.JPG 1375139196-20.JPG
    A FEW MORE PICS TO FOLLOW
  7. presscall
    Simmering to full blast on the TD cap then some night shots illuminated by - appropriately enough - an ex-Army Vapalux
    1375139779-21.JPG 1375139790-22.JPG 1375139801-23.JPG 1375139812-24.JPG 1375139828-25.JPG 1375139840-26.JPG
    My conclusions about the stove at this end of the fettle?
    In part, as I'd already judged - an expensive flop commercially with needlessly complex burners.
    That said, the burner control valves are immensely robust and with the 60-year-old packing seals replaced with a better modern equivalent, the burners work really well and are surely capable of shrugging off another 60 years of use, no bother.
    Those jet discs are a great idea and the durability of stainless steel suggests they'll stay on spec in terms of unworn jet orifices, better than brass jet nipples.
    Shut-off of the fuel is positive and certain, unlike those military No.2 (and No.3) stoves with the roarer burners and the ridiculously long control spindles and the burners regulate smoothly from off through simmering to full power.
    The heat shield barrier between burners and fuel tanks is effective (metal on top, woven asbestos-based material on the flip side) and the fuel capacity offered by the two tanks is impressive in such a compact package.
    I'll be using it often, providing I'm trucking it to a picnic spot and not backpacking.
  8. idahostoveguy
    idahostoveguy Subscriber
    Potato Country USA
    Excellent post John. And, no, I don't mind at all to being associated with your work. Thank you very much. It's an honor.
    You've turned an otherwise poor stove into quite a nice working unit. I will be able to fettle mine based on your brilliant work.
    sam
  9. Spiritburner
    I agree. For this stove, a real diversion from the norm, it not only helps identify the make & model but shows the guts as well. Thanks John.
  10. kerry460
    kerry460 Australia Subscriber
    Tasmania , Australia
    G,,day John . somehow I had missed seeing this write up . as others have said impressive indeed.
    I like it regardless of or because of its complexity .
    top job on the work you did to it :thumbup:
    but as I now know having seen other examples , I should expect it :)
    cheers
    kerry
