Valor 55
Discussion in 'Valor' started by hypan, Nov 22, 2013.
  1. hypan
    This Valor 55 came Thursday so I've spent a bit of time cleaning it up.
    but one thing does the spirit pan come off the burner.
  2. Tony Press
    Yes. It's probably stuck on with age and fuel residue. Soak the burner/spirit cup in 1/3 vinegar/water or a degreasing solution for 1/2 hour then try twisting it gently as if to unscrew it ( its not screwed on, though). Failing that, tap it gently in the centre away from the top of the burner.
