What is this, M1950?
Discussion in 'Military' started by Billofthenorth, Aug 14, 2016.
  1. Billofthenorth United States
    us
    I saw it up for auction and figured I'd give it a new home unless the price gets too high but I'm not quite sure what it is or what is missing. The post says it's missing a knob but doesn't show the back side well.
    A little help?
  2. Billofthenorth United States
    us
    Darn my quest for knowledge. Once again I asked a question with the answer easily obtainable online. I guess that happens with some of us prehistoric, pre-computer public library raised throw backs.
  3. HercL4D2
    HercL4D2 United States Subscriber
    U.S.A.
  4. Etherman
    Etherman United States Subscriber
    USA
    It appears that it was painted with blue paint over the original green. They also came with a wrench, spare generator and a two piece aluminum case
  5. Billofthenorth United States
    us
    Thanks for the replies....I may bid on it. I'll let you know how it goes if I do.
  6. Billofthenorth United States
    us
    I won it and it arrived yesterday. Rogers, 1966.
    This thing has patina and I'm going to keep it as is as much as possible. All those scrapes, scuffs, scorch marks, the old paint lurking and showing through the blue and even the rust give it character.
    The seals and gaskets, knob and tool (already ordered, also arrived yesterday from OCP) will be replaced as I take it apart. I put denatured alcohol into the fount to help clean out the green scale, though otherwise it looks pretty clean and it pumped for a while and held pressure. But the leather pump cup tore off inside the tube so that has been replaced with the new one after a short delay to figure out how to separate the two parts of the cap. The pump handle contained the expected spare parts though the graphite packing didn't survive the 50 year journey. The pip still seems pliable as does the gasket and after the leather cup was replaced I was able to get alcohol flowing and even a short burn and shut off, though I know it uses white gas. I don't think I'll try a real burn until I get the needle gasket replaced.
    One question, I placed a Nitrile ring in between the two cap portions to keep them separated a bit and ease in opening the pump. I've found I need to screw down the bottom portion first to get a positive seal with the tank, then the top portion but there doesn't seem to be any other problems from it. Does anyone foresee any trouble that might result from this?
  7. teckguy_58
    Spokane, WA
    @Billofthenorth
    Hi,
    Looks like you have things taken care of. You will also need the control nob screw to hold the nob in place.
    http://www.oldcolemanparts.com/product.php?productid=124&cat=23&page=5
    You might want to get a extra generator and an extra rebuild kit. Also maybe an extra graphite packing.
    http://www.oldcolemanparts.com/product.php?productid=3256&cat=23&page=4
    http://www.oldcolemanparts.com/product.php?productid=22&cat=23&page=1
    http://www.oldcolemanparts.com/product.php?productid=2280&cat=37&page=1
    Looking forward to seeing your stove up and running.
    Norman
  8. Billofthenorth United States
    us
    @teckguy_58
    Thanks. I didn't notice the screw or packing when I was ordering parts. They are now on my wish list for the next order. :)
    ~Bill
  9. teckguy_58
    Spokane, WA
    Hi Bill,
    Glad to be of some help.
    Norman
  10. Billofthenorth United States
    us
    ...and now the money shot. Function test. Love that roar and how easy it is to light up and a near instant shut off. IMAG0009.JPG
    IMAG0004.JPG I forgot to order the screw - will be added to next order. IMAG0003.JPG It hasn't been cleaned up much, I'll get the grit and grime out in due time but that paint job will be staying the same.
    IMAG0005.JPG Now without the O-ring.
    IMAG0007.JPG One more of that blue!
    I didn't manage to get a picture but the pre-heat cup has a rope type wick in it. Asbestos?
  11. teckguy_58
    Spokane, WA
    Hi Bill,
    Great job getting the old girl up and running.
    Norman
  12. ArchMc
    Mojave Desert
    Could be, or maybe fiberglass. Either way, you shouldn't need to mess with it.
    ....Arch
