Wick stove
Discussion in 'Stove Paraffinalia' started by presscall, Apr 23, 2011.
  1. gieorgijewski
    gieorgijewski Poland Subscriber
    this is "class of art" - easy to forgot or missing
    (Short Gaphical Message ?)
  2. presscall
  3. Ed Winskill
    Most interesting, indeed.
  4. kerry460
    kerry460 Australia Subscriber
    Tasmania , Australia
    G,,day John
    before tape .
    how about putting some thread or thin string down through the opening .
    using a needle attatch them to the wick and use them to help pull the wicks up and through .
    kerry
  5. presscall
    Could have @kerry460. Depends how securely the needle would hold in the weave of the wick without fraying it I suppose.
  6. OystrPir8 United States
    Oakland, Ca
    Thanks John,
    I just came across it on the internet recently and thought it was cool, and was one of the only depictions I had come across of a stove like this in use. I just pulled mine out and got to work on it. The wicks are SUPER long but now moving freely. I haven't lit it up yet. Do you recommend kerosene? I also need to trim the wicks a bit. Did you use scissors or is there a better tool? I also just ordered a neat enamelware kettle to keep on top of it. I hope to have it up and running before long. I'd also like to test out a stovetop oven on it to see what kind of temperatures I can reach.
  7. OystrPir8 United States
    Oakland, Ca
    image.jpg Here is mine waiting to be filled and lit.
  8. presscall
    Kerosene, yes. It's the only suitable and safe fuel for the design.
    Trimming the wick? To cut a wick to length scissors would be fine. I use metalworking shears because I have them and the leverage is better on the thick-ish fabric, that's all. Trimming a wick in 'wick speak' is something different however. When the stove has been in use for a good while a black carbon crust forms on the lit edge that ultimately inhibits and disrupts even burning. Trimming off that crust is more a light scraping action with a blade, avoiding cutting back to the fabric.
    While on the subject, the correct way to prepare a wick is to install it in the burner and before it's been wetted with the fuel and with 1/8 inch or so exposed run a flame along it to scorch the fresh edge then snuff it out before it smoulders down to the bulk of the wick. The procedure aids subsequent flame propagation. Once wet with fuel that intial scorching won't be possible, but it's a marginal loss if not done admittedly.
    Your stove's a beauty and that kettle's a fine choice to accompany it. I expect that with a Coleman oven you'd be limited to the cooler end of the heat range, but worth a try. Something like an Omnia ('doughnut' shaped stove top oven) would probably give better results.
  9. OystrPir8 United States
    Oakland, Ca
    Here it is with the kettle on top. I'd really like to get her up and running (as cleanly and as safely as possible.) The wicks are old but I don't think heave ever been lit. Awfully long too. Should I cut them and save the rest for the future or is it better to leave them long? Can I find replacement wicks?
  10. ArchMc
    Mojave Desert
    I'd leave them long. If you ever need a piece of wick that size, you'll know exactly where it is...
    ....Arch
  11. OystrPir8 United States
    Oakland, Ca
    Thanks, Arch. Just wanted to make sure it wouldn't cause any problems.
  12. OystrPir8 United States
    Oakland, Ca
    I have finally trimmed the wicks and test fired the stove. Haven't lit it indoors yet but I hope to do some cooking soon. I've also posted a youtube video:
    Would love to hear/watch your thoughts.
