5213 Alcohol Restrictor *MUST be fitted!
5163 Gasoline Restrictor *Must be fitted!
according to instructions using fuels other than paraffin the restrictors must be fitted.
I mentioned the stuffing box its:
2194 Stuffing Box
From the instructions I have it looks like you can use either nipple for use with Alcohol but suggests that for Alcohol you should change the nipple as well.
Instructions warn strongly against using the Alcohol nipple with other fuels.
I'll check them both and get back to you.
