adibrook
oh, well...
August 29 2003, 8:05 PM
So mine isn't a spiritbranner. But whatever it is, it's hopeless with kero and runs on meths. The jet hole doesn't look too big either. I couldn't prick it with my SVEA 123 pricker, it was too bit. Should thoes burner have a built in pricker?
PW
RE:No.107
August 29 2003, 9:11 PM
Yep, that's what the tap at the bottom is for...
PW
adibrook
dismantling
August 29 2003, 9:35 PM
I tried to dismantle my burner, but i couldn't figure out how. Can anyone tell me which bits are removable, and how. I think the pricker needle is either bent or broke, but i can't remove the jet to check, because the basket is in the way. and how do you remove that?
Radius43B
Tabs
August 30 2003, 10:53 AM
My Radius 43B has a set of tabs to hold the burner domes. That is probably the only reason it was complete when I bought it.
Check the pictures on the web-page - http://members.optusnet.com.au/lynnmiller/radius43b.html
P. Lynn Miller
http://members.optusnet.com.au/lynnmiller/index.html
< Previous Page 1 2 Next >
  Respond to this message
