I have a mint condition Optimus 00, except the pump valve leaks fuel into the pump chamber. It is a very slow leak as the stove will hold pressure and run nicely, but fuel leaks from the pump if the stove is stored with fuel in the tank.
Anyone know if the pump valve on this can be removed, repaired?
JGB
Syracuse, NY USA |
