| Cleaning Burner heads.October 13 2003 at 3:12 PM | Stuart |
| I have a couple of silent burner heads for 5s, and some roarers to put on them, that I want to clean.
I fancy trying the ageressive approach suggested elsewhere, heat them red hot and plunge in a dilute mixture of water and acid.
Not having done this before can anyone answer a few questions ?
1. Not having access to a forge, would the burner heads get hot enough in a well lit pile of BBQ fuel ?
2. Can you clean the silent burner domes and roarer spreader rings in the same way ? |
| | Author | Reply | rik
| Cleaning Burner Heads | October 13 2003, 3:36 PM |
I took Alberts advice on cleaning stoves and soak brass parts in a citric acid solution for a while (I get mine in powder form from a local home brewing store), then rinse in a bicarb solution (to kill any residual acid). The brass is very easy to clean up after that. Check the links on this site for Albert and he gives full details.
Rik | |
