Just killed my m1941
April 23 2004 at 8:12 PM
adi brook
I tried to prick it, but the pricker handle was so rusty that it broke!
Now what do i do?
Is it possible to get a new pricker handle (and fit it) or will i have to get a whole new valve body?
Any idea where i can get one?
 Respond to this message
AuthorReply
Dan Leeds
homemade prickers
April 23 2004, 11:27 PM
Adi I make prickers out of the bristles from wire brushes.I have had good luck with the small brushes shaped like a tooth brush. I take a micrometer to the bristles.I have found .004 thru .008 thousandths. Sorry I haven't looked for metric sizes. I creat a handle from tin and crimp the end over with wire crimpers. Dan
Handi Albert
Adi & Dan
April 24 2004, 1:58 PM
Adi is talking about his 1955 army stove with a built in pricker not the 3 soldered leg type.
Adi sorry I don't have one but Look into the Coleman lights ( 242, 249, 247) this type I can't remember all the models that will fit. These are the lights with a nickel tank I think was called scoots. The more modern green painted tank (201 type) may fit as well, I have not tried them. You will probably have to bugger up the calmanite seal to get them out.
I sergested this I think it was to Chuck , going back a month or two ago.
Who ever it was how did you go with it? Have you tried it yet?
Albert
Dan Leeds
misunderstood
April 24 2004, 3:06 PM
I got the impression Adi had the wire stuck in the jet.I was tired at the time. Frank Bebb at Old Town Coleman is a great source for old Coleman parts.http://www.oldtownyucca.com/coleman/ Frank is a great guy who will help you get that stove fixed up. Dan
Chuck
Broken cleaning needle
April 26 2004, 12:46 PM
Adi,
You will most likely need to find a replacement. I too broke the lever off of my Aladdin / PW 1942. Once those parts are damaged or broken the whole valve assembly needs to be replaced. At least that is how it seems to be at the moment. I just bought another stove and used the parts to create one good working model.
Trying to buy a broken one for parts put me in the same boat as other collectors who were trying for the same thing and the price of a parts one vs a working one was slimm so I waited for one that was in my price range.
It would be interesting to see if the lamp assembly Albert has referred to would work. I just never looked around for a lantern ( 242, 249, 247?) that had the same type of assembly.
Chuck
Georgi
you guys are harsh
April 26 2004, 1:39 PM
Take some time with these babies......a little love goes a long way before you put the bigger hammer to em'
Anonymous
Ebay repair kit
April 26 2004, 8:30 PM
adi brook
m1950 comes to the rescue!
April 26 2004, 9:15 PM
I think i still have an intact spares kit in my M1950 pump shaft. I wander if the graphite packing in that will fit the m1941?
