1933-37 Primus 71 (no date stamp)
Discussion in 'Primus No:71' started by presscall, Feb 21, 2017.
    Has a soldered pin safety device, which we know dates it to post-1931, instruction leaflet appears to have a printer's date of 1933 and the stove tin design (Primus 70 pattern) was phased out by 1937.
    Basically a regulated version of a Primus 70, which was marketed alongside it for a time. The later '71' dates from 1951 and also has a soldered pin safety device installed.
    I wanted to check the condition of the wick - which wasn't in bad shape but I replaced it anyway. Though there are no spanner flats on this model, I use the wooden block and G-clamp method as a matter of course. Works every time.
    (That's the new wick installed).
    Blissfully simple, good therapy after getting my head recently around the complexity of the workings of a Soto Muka pump.
    ... or an Enders 9061D.
    Assembled (the Primus!)
    Stove tin details. Direction in several languages on the drop-down front inner panel of the need to drop the front when the stove's in use.
    Stove tank engraving.
    The overpressure/overheating safety device pin anchor points.
    What I interpret may be a reference to 1933 on the instruction leaflet. I may be wrong, but it's a plausible date.
    Instructions in English, refers to the re-soldering of an activated safety pin device. Those were the days, when a manufacturer could assume the customer had the skill and a soldering iron.
    Fuelling up using the original filler funnel.
    I never tire of hearing the distinctive sound.
  2. Tony Press
    @presscall
    Very nice, John.
    Working on this stove must have been very "Zen" compared to the Soto Mika pump!
  3. presscall
  4. shueilung.2008
    shueilung.2008 Subscriber
    Uruguay
    @presscall
    Nothing better than an excelent, and over all, practical to maintain, design. In Spanish when something is gratuitously complicated we say: "rizar el rizo" (curling the curl)
    Enrique
  5. z1ulike
    @presscall you are an international treasure for your contributions to the stovie community. :clap:
  6. Metropolitantrout
    Metropolitantrout Subscriber
    Santa Cruz, CA
    Nice John. Kind of a "tweener" stove where they used up some of the old 70 parts with the next iteration of early 71 parts. Jerry
  7. ArchMc
    ArchMc Subscriber
    Mojave Desert, California
    It is nice to see the elegant simplicity of the 71 regulator.
    ....Arch
  8. tofta
    tofta Subscriber
    Trondheim, Norway
    You have a thing of beauty there, and your presentation is superb. For those who have not tried – this type of presentation takes time & dedication, both with this stove(s) and not least the experience behind it.
    About the dating of the instructions: I have a number of date stamped Primus stoves with instructions and those numbers correspond very well. So I agree, my money is on that being the year printed.
    My favorite petrol stove of this type is a 71 shorty with an E-type(!) tin/potholder/pot - and with the funnel of course. Those filler tubes are so tiny not much else will work.
    Thanks, and all the best, e
  9. presscall
    Well I've learned something, a saying I'll have use for often in future. Thank you Enrique.
    Oh, I don't know about that Ben. The real achievement is the collective contributions of all CCS members past and present. That phrase from Enrique's a gem!
    Thanks @tofta. All the best to you too.
  10. Ian
    Ian Subscriber
    Notwithstanding the filler cap lark, there's a couple of gaps to fill in that line-up.
    Excellent fettle, as usual.
  11. presscall
    Only copying The Master, Ian!
  12. MrAlexxx
    MrAlexxx Subscriber
    @presscall Just looking at your pictures I could hear it. lol :) Sounds very nice.
  13. presscall
    A favourite, getting plenty of use.
  14. Tony Press
  15. Optimust
    Hi John, What a great abstract image that is. Ideal to print on Tee shirts, stove meet apparel perhaps. Again you excel.
    Best to you Optimust
  16. presscall
    Thanks @Optimust. You're very kind.
