5mm pips
Discussion in 'Stove Forum' started by snwcmpr, Oct 18, 2021.
  1. snwcmpr
    I drilled the end of a bolt with a drill, not sure which size, but close to .210 and/or 5mm.
    Then I ground the bolt to a taper, like a punch, and made my own pips.
    Cut off the head, mount in a drill, and add a little oil to make it cut easier.
  2. Jaime Massang
    Jaime Massang Australia Subscriber
    5 Piece Supatool Hollow Punch Set - Bunnings Australia
    Applaud your machining skills.
    I had to resort to buying a set of hollow punches.
    I recall reading on this site that cleaning and filling the pump tube with fresh kerosene and with a solid squirt into the tank was a good technique to clear the NRV.
    Should be adopted as routine maintenance.
  3. HunterStovie
    Parker, Colorado, USA
    I've got a .195" punch from a set I bought from ebay and 70% left of a 3mm thick Viton sheet. 5mm is .1969"
    They are a perfect fit for my enders. But I also bought some from Old Coleman Parts "here" or "here" that were the same size.
  4. snwcmpr
    I recall that the brass pip holder was .210???
  5. HunterStovie
    @snwcmpr
    I believe you are correct @ .210" for the holder, but I've not browsed for those in 5 or more years so don't trust my memory.
  6. snwcmpr
    Memory is a thing of the past.
  7. snwcmpr
    Not machining, just hand tool work.
  8. Ian
    Ian Subscriber
    West Yorkshire
    :lol:
  9. Jim Lukowski
    Jim Lukowski United States Subscriber
    New Jersey, USA
    Which pips need to be that size? NRV? SRV? Or are they both the same?
