96 help needed
Discussion in 'Stove Forum' started by IvanN, Oct 5, 2019.
  1. IvanN
    N.E. Oregon
    I have a burner bell stuck to the lipstick on a Optimus 96 I recently got. Before I go to town on it with the ballpeen hammer, I thought to ask for advise from you fine folk. Any suggestions on how to proceed? Thanks in advance, Ivan
  2. boknasild
    boknasild Subscriber
  3. IvanN
    N.E. Oregon
    Thanks for the link @boknasild ! Exactly what I was looking for.
    Ivan
  4. pyro_P Australia
    Westraya
    I'd hold onto the lip-stick end, then apply some soft heat to the burner bell.
    Place some rag under-neath for the bell detachment/drop.
  5. hikerduane
    Tap smartly, repeatedly around the base of the bell with a rubber handled screwdriver or hammer of some sort, not striking the flared part of the bell. Heat also usually does it.
  6. Rangie
    Rangie Subscriber
    And be wary how much heat you put into the vapouriser, too much and the solder holding it into the bottom-nut will let go :doh:
    Can make things frustrating.... :lol:
    Alec.
  7. Cookie
    Florida
    I'm glad that you asked this question as it is the next stove on my list with the same issue. I am considering mounting it in my vise bell down, pouring ice water into the vaporizer, heating the bell at the junction with a butane torch, and tapping it with a light wooden dowel to try to free it
  8. hikerduane
    Use a propane torch, you want to heat the base of the bell which is the area in contact with the lipstick. Heat up all around the base of the bell. I mount the flats of the lipstick in a vise, then twist the bell with a screwdriver while heating. A butane torch is going to be slow.
  9. snwcmpr
    snwcmpr Subscriber
    Has anyone used penetrating oil?
    I have not yet had this problem.
