A Juwel, but in the rough
Discussion in 'Stove Forum' started by Haggis, Jun 14, 2019.
  1. Haggis
    The pair for $15 this evening, everything moves on the Juwel. I guessing it burns kerosene, but I’ve no notion as to what model it is, whether it’s missing parts, or how to begin cleaning it up. The last bit should be easy enough to google, but any help getting me started with identifying it, getting running, or cleaning it up will be much appreciated...
  2. Mark Layman
    Mark Layman Subscriber
    USA West Virginia
    Hello Haggis. That Juwel IMHO should be cleaned with detergent and water only after disassembly. Make sure the burner is not clogged.
    Clean the tank inside. replace all washers and NRV / pump leather if it is too brittle. Maybe remove the rust from the pot supports but just clean and get it working. That thing has history and was obviously nit used much just stored poorly.
    As for the other stove it seems to be a brute and heavy. i would bet it can be a safe stove to use also but i surmise it is a smelting furnace of some sort.
  3. Haggis
    Thank you,,, Thank you very much,,,
    This is the first of this sort of older style European stoves for me,,, Getting it cleaned up and going will be exciting...
  4. Blueflame
    Blueflame Canada Subscriber
    Montreal Canada
    The other beast is a Unique kerosene plumber's furnace. I would like to see more pics and compare with my Model 55. See post here.
    Unique MFG Co No 43
    Is "Unique' stamped on the pump knob?
  5. Haggis
    Thank you Blueflame,,, I hope these help...
    I had no idea what it was...
  6. Blueflame
    Montreal Canada
    Ok...Unique it is. Yours is a slightly different model as it has the air bleed device, the model 55 does not have it. I cleaned mine up and it roars.
    I also have a Juwel 41.
  7. Haggis
    Very nice that...
