A Monitor Prov Pat 32607, ? may be
Discussion in 'Stove Forum' started by CRAZY CRAB, May 6, 2021.
  1. CRAZY CRAB
    CRAZY CRAB United States Subscriber
    Addlestone UK
    got this today, looked at a few pic, I think it could be a monitor 3 variant, now, have played with it, replaces all seals, but, is there some think in tank, some kind of anti tilt thing, there is some kind of box, plus, the tube/vaporizer, , some think inside it, that rattles , its not the wire gorge, its above it, and it is heavier then normal, is it some kind of safety thing, then you got that cut out were you input the fuel, see last pick and last of all, the flame speader has been welded on, and last last time, of all, the door is missing, i can make one
  2. CRAZY CRAB
    Addlestone UK
    why does this stove still fire up when no pressure in tank, it should go out
  3. presscall
    Little paraffin stoves, small tank often self-pressurise (a bit) with the priming charge. Heat’s conducted to the fuel. Bigger stoves, the heat from priming gets conducted away (apart from the burner) by the greater mass of brass.
    ‘96’ stoves do it a lot.
  4. ROBBO55
    Nice stove! :thumbup:
    Have you had the vapouriser off and checked the condition of the gause? I'm assuming it's holding liquid fuel and just taking a wile to vapouriser it.
    And / or
    There may be a partial blockage in the feed pipe that is keeping fuel in the vapouriser after the cap is removed.
  5. threedots New Zealand
    Hello @CRAZY CRAB . It would be interesting to see what the rattle could be caused by. John
  6. Jaime Massang
    Jaime Massang Australia Subscriber
    Could the gauze be a bit dirty wherein it is acting as a one way valve i.e. it lets fuel up the riser which loosens particulate matter in the gauze mesh but as soon as it vaporizes ( and thus expands) the back-pressure forces the 'dirt' particulates back into the mesh without pressure reaching the tank? The pulsing effect effect would last until the trapped fuel in the riser is burnt off and a pressure equilibrium is reached between the riser and the tank when the combination air vent / filling cap is unscrewed or left off.
    If my theory is correct, I would take the gauze out and see whether there is loose particulate matter trapped in it.
  7. CRAZY CRAB
    Addlestone UK
    gauze is ok, can move it around, looks clean, but its the rattle, it is heavy for a lip stick, and some think in tank, when you pump , there is a pause then the fuel comes up, will spend today investigating, this stove is not a normal stove, would it have some kind of anti tilt thing init, if it got knock over it goes out, and take more pics of lip stick,
  8. Jaime Massang
    I don't own one of these. You could be right. I imagine a captive ball bearing in the lipstick's bore or pick up tube that could shut off the burner if the stove is in a tipped over position or the like. Very interested in what you may find.
  9. kerophile
  10. kerophile
    Provisional Patent 32607 :
    “The stove had a non return valve under the burner which allowed the stove to be carried with fuel in it without spilling. This was given a provisional no of 32607.”
    From a Bryan Miller post:
    1939? MONITOR NO 2 PICNIC STOVE
  11. Jaime Massang
    Yes. Provisional patent applications are not published so the invention is kept confidential until a complete application is made within 12 months.
    The complete application for which prov.pat. 32607(filed Nov 10, 1938)provides a priority claim is UK patent 521020(lodged Nov 10, 1939).
    This relates to a spring loaded valve in the riser which shuts off if there is no pressure in the tank or is insufficient to overcome the compression of the spring e.g. in storage.
    This is referenced in the CCS patents library under patents for Monitor.
    Regards, Jaime.
  12. CRAZY CRAB
    Addlestone UK
    getting in touch with Pat office, to get copy of plans, I hope
    plus I have seen 3 types of this stove, the quiet one, the noisy one, and then a wield looking one, looks like a bolt,
  13. CRAZY CRAB
    Addlestone UK
    one problem solved , the lipstick, and gauze, got it out, after i had got the lead seal off, which was welded on kind of thing, gauze was super rolled up tight, and longer then the other gauze I have pulled out of 96s, opened it up carefully cleaned it, rolled it back up, cleaned out lipstick, rattle had gone, it was the super rolled up gauze bagging against the sides, now a good fit, on rattle, now to look at the tank
  14. Jaime Massang
    Good you could get the gauze out. It would have sieved and collected particulate matter over the years.
    It could also be whoever replaced it previously may have used the whole roll supplied rather than trimmed it to a correct size.
