ac/dc adapter for electrolysis
Discussion in 'Fettling Forum' started by MarcCote, Jan 25, 2021.
  1. MarcCote Canada
    Ottawa, Canada
    I'll like to try my hand out at electrolysis to remove rust off a coleman manifold. Can somebody confirm that this will do the job ? Any links on how to hook everything up ?
    Cheers!
  2. kerophile
  3. Brenneman
    Brenneman Subscriber
    I use a 19 Volt DC 5A laptop charger and it works flawlessly.
    You should be fine with this charger/adapter.
  4. MarcCote Canada
    Ottawa, Canada
    Great! Thanks for the links and the info fellas. Will try that this evening.
  5. Rangie
    Rangie Subscriber
    24v is a bit vicious.
    12v is nice for a good blast and 6v for a gentle simmer. Use a traditional transformer-style battery charger, they are the cheapest and easiest way to do it.
    Alec.
  6. MarcCote Canada
    Ottawa, Canada
    I found another adapter that is 8.2v and 2.5A. That would seem to be more reasonable. I think I'll try that tonite.
  7. cottage hill bill
    cottage hill bill Subscriber
    Alec, I have to disagree about his power source being too strong. I use mostly old laptop power bricks which are 19v 3-4a and they work a treat. In fact I normally use several of them at once especially if I'm doing a big piece like a suitcase stove case. i've found the smaller power supplies often have trouble overcoming the resistance of larger parts (I also do old tools) like a vise part. The guys who are into farm tractor restorations use 240v arc welders as the power supply when they're derusting a big component like an engine block or transmission case. They most I've ever pushed it was a setup that gave about 40v and you will get a little tingle from that if you stick your hand in it. Probably won't go there again, but I was working on a big lump of iron on that project.
