Not sure, I know it has an o-ring on the pump. Does it have any replacement parts in the check valve? Thanks
@Timothy Culliver The NRV will have a small rubber piece, a "pip". Could be cork as well, or maybe even leather. Just a small, circular dot. THe pump cup should be leather, and the gasket was probably a square cut Oring originally, but a regular Oring would work fine.
