AGM 520 - mostly
Discussion in 'Military' started by presscall, Jun 5, 2012.
    Something of a collection of parts rather than 'as it left the factory'
    'As it left the factory' + 69 years
    Now, the AGM fuel tank has become the windscreen ...
    ... and a brass, somewhat dented, Coleman fuel tank dated 1945 replaces the AGM tank
    The AGM fuel tank was full of rust pin-holes. I've chopped it up here ...
    ... to reveal one of the larger piercings on the outer rim of the generator mounting boss
    Along with such corrosion were gummed-up components ...
    ... and just this component I could retrieve from the non-return valve
    Here was a dilemma. I had a Coleman tank that takes this type of NRV and locking rod ...
    ... and the AGM NRV locking arrangement is a different pattern, with the AGM valve bulkier, so even if I could have removed it from the AGM tank (I couldn't) it wouldn't have fit the Coleman tank.
    The solution was an adaptation of the Coleman NRV and locking arrangement to make it compatible with the AGM pump
    Back to that windshield made of some sheet steel retrieved from the AGM fuel tank.
    The stove came to me without a windshield and though I at first thought of making one up out of sheet brass to match the Coleman fuel tank, I decided to incorporate a memento of the AGM tank and brazed up a cylinder from a portion with the 'US 1943 AMERICAN' legend on it.
    Here's the windshield already having been silbrazed up from sheet and ready to silbraze onto the burner flame plate lugs
    Complete and cleaned up
    Fuel/air stem, generator, burner bell and windshield ready to instal in the fuel tank
    Before firing up the completed project, I reminded myself how it should look fired up by giving my Coleman 520 a test firing
    The 'mostly' AGM fired up fine, the orange flame here settling down to a proper blue colour after a while
    Next job's to make up a set of those pot rest 'fingers'
  2. idahostoveguy
    idahostoveguy R.I.P.
    Hi John,
    Frankly, a fantastic fettle!
    Thanks,
    sam
  3. RonPH
    A very good fettle indeed. What a gunked up fuel pick up tube but I was confident you'd sort that one out :thumbup: Congratulations!
    Ron
  4. davidcolter
    An inspired use of the AGM tank!
  5. flivver
    Arizona
    Quite creative John. You now have the rarest of the 520's. Mike...
  6. teletim
    Clever stuff as usal :thumbup: :)
  7. itchy
    Very nice and creative.
    And it reminds me to light up one of of my WWII era stoves tonight in remembrance of D-day.
