AGM Backpack stove No.20
Discussion in 'AGM - American Gas machine' started by Motoshi Makino, Jan 5, 2011.
  1. Motoshi Makino
    It is a coil burner of AGM. It is very small and it is lovely. The feature has been that the opening and shutting valve of the fuel adhered.
    Motoshi
    1294228153-PB173040s.jpg 1294228181-PB173062s.jpg 1294228194-PB173061s.jpg 1294228217-PB173058s.jpg 1294228236-PB173054s.jpg 1294228254-PB173056s.jpg 1294228286-PB173046s.jpg 1294228299-PB173043s.jpg 1294228315-PB173045s.jpg 1294228331-PB173047s.jpg 1294228345-PB173048s.jpg 1294228370-PB173051s.jpg 1294228385-PB173060s.jpg 1294228403-PB143031s.jpg
  2. Admin
    Admin Courtesy of Iani
    Hi Motoshi
    It is a stove of outstanding quality.
    Beautiful. Congratulations on your acquisition.
    Kindest regards
    Ian
  3. davidcolter
    Is that an alcohol or gasoline burner?
    The position of the valve implies that fuel vaporization is happening very low down, actually inside the tank.
  4. Motoshi Makino
    Hi.
    The use fuel is gasoline.
  5. itchy
    Very nice. Great pictures also. Thanks
  6. Lance
    Northwestern Illinois
    Ooh i have to have one of these.
    It looks like it is a real hot burner, and would boil a liter of water real fast.
    I may have to make my own now i've seen one.
    lance
  7. Spiritburner
  8. mr optimus
    mr optimus Subscriber
    Hi Motoshi very nice indeed one of the nicest coil burners i have seen the tank has realy nice ornate style and like you i like the regulator feature on it
  9. nzmike
    Never seen a valved one, very cool! As twitchy as they are, I do have a soft spot for them. 8)
  10. Motoshi Makino
    Hello every one.
    Thank you for a great comment.
    Moreover, we wish to express our gratitude for teaching the photograph of Ross.
    It is a surprise that this knob's it becoming a knob in the coffee cup of the tinplate case. :shock:
  11. Spiritburner
    You're welcome. ;)
    I originally thought the hole in the lid was for a handle but I think now it may be to ease removal - to stop a vacuum forming.
  12. Sparky
    Houston, Tx area
    Mitoshi, I visited your site. Such beautiful photographs! Your fuel bill must be astronomical!
  13. Motoshi Makino
    Hi Sparky.
    Thank you for the Web site visit about me.
    I am bad man who contributes to global warming.....(It is a joke).
    The knowledge of my stove and lantern is still a baby.
    Regards,Motoshi
  14. gunsoo
    hello motoshi.
    i saw the first coil stove with handwheel.
    very beautiful design. :p
    i'm korean lantern collector. do you remember me?
    and i'm "classic lantern and stove" cafe member.
    :o
  15. Motoshi Makino
    Hi gunsoo .
    Welcome.
    The stove manufacturer in South Korea had heard that there were 80 or more before.
    Very to our regret, it doesn't remain now.
    Please introduce the stove of a lot of South Korea to the member of CCS.
    regards,Motoshi
  16. benfast
    Good day!
    I have one of these stoves, complete with case.
    It immediately became clear to me what the hole in the lid is for...
    No, it is not to relieve a vacuum to make the lid easier to remove.
    It allows the lid to become a very effective and easy to use 'funnel' for filling the tank with gasoline!
    I think it is a brilliant design. The height of the hole in the lid limits the amount of fuel that can be poured into the tank in one shot, and it is pretty much spill proof!
  17. z1ulike
    I pulled mine out and gave it a go. Unfortunately the gasket under the fill cap was old and leaked. After the stove burned for a while, and the tank became pressurized, fuel was forced out and I had a huge fireball in my kitchen. Of course it happened just as my wife walked in. I quickly found a pot and turned it over the stove and smothered the fire. Close call.
  18. presscall
    Should a newbie read this, note that gaskets and seals should be checked and replaced as necessary before firing up a new-to-you stove.
    Essential also to fire up a stove outdoors. True, some stoves were intended for domestic, indoor, use but our hobby centres on antique stoves and even with new gaskets/seals stress cracks in brass fonts and unseen internal corrosion spots in steel fonts or bases can leak fuel when pressurised.
    Fire Chief (retired) Ben, health and safety warning posted!
    Congratulations on a lovely coil burner.
  19. z1ulike
    @presscall Point taken. I did look at the gasket before firing the stove up. It was there and didn't have any obvious cracks. I think it's just hard and not fully sealing.
    Firing it up outside is a good idea but it's hard to see the flame out in the sunlight. You might have noticed that there is no pre-heat cup on this stove. Getting it started is not easy. I held the coil over my kitchen range until it lit.
    BTW I'm a retired Fire Captain not Chief but thanks for the promotion!
